Author Topic: Small turbo Mk4 Golf GTI tuning another way  (Read 23248 times)
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Small turbo Mk4 Golf GTI tuning another way
« Reply #50 on: 17 August 2011, 20:02 »
Bloody iPhone
Should say
Free power for same amount of fuel and boost.
 01455 617233
Offline LEBMK4GTI
« Reply #51 on: 18 August 2011, 11:26 »
Before I reply, I want to thank you a lot Nick for your help you are showing, especially that you are not obliged to do so. I REALLY APPRECIATE IT!!!  :smiley:
Dial in timing using det cans and knock sensors to listen for pinking ( pre detonation of air fuel mixtures)
what is a "det cans" and where I can find the "knock sensor" - is there any links i can follow?
Quote
To dial the timing in we use 7maps, ignition maps x2 related to cam positions, 2x ignition correction maps related to temps, and knock control recovery maps.
can this be done when I with Lemmiwinks? or SPS3? if not what should I do especially that I am going with Revo stg2
Quote
The higher the peak boost the greater the peak cylinder pressures, and the mixtures burn quicker and easier, so with 25psi peak boost less timing is needed to get a the combustion to force the piston down at just after TDC
how I get less timing with Revo? and what is a TDC? I heard that Revo got the SPS3 that can adjust boost and Timing, would this help?
Quote
As the peak cylinder pressure drop along with the boost at the higher rpms we can add timing to compensate for a slower flame front (start of combustion).
Can you explain how I can add timing at higher RPMs??? What did you mean by “add timing to compensate for a slower flame front” ????
Can you explain me more about the Degree??? And it is used for what and how do I should adjust it???
Many thanks in advance for your support and Help,
Sas
Offline LEBMK4GTI
« Reply #52 on: 27 October 2011, 09:03 »
Bump for Nick!!! :smiley:
Offline RTechUK
« Reply #53 on: 27 October 2011, 13:07 »
All basic tuning info above, if you google it you will find much more info than I can put in a post.
How your 001 setup going?
 01455 617233
Offline LEBMK4GTI
« Reply #54 on: 29 October 2011, 10:11 »
Thanks for the reply mate :smiley:, I will surely google it.
My 001 setup is doing well for a none mapped car, now i have a lot of mods done, all is needed is the remap. I got an ECS stg 1 Clutch KIT, all the bushes in Poly, Metal link for the sway bar, Forge TIP, DV007p, FMIC, N249 bypassed, Oil catch can, new coil pack, NGK sparks BKR7E, ECS N75 Race, I am relocating the DV this week-end, and I bought a Overboost kit like you advised and i will install it when i do the remap. I just want to know if would you advise me to get a FORGE actuator? and with which spring? :undecided:
Check my build thread here:
http://uk-mkivs.net/forums/t/432664.aspx?PageIndex=4
Cheers,
Sas
Offline LEBMK4GTI
« Reply #55 on: 21 November 2011, 12:39 »
Hi Nick,
It is been a long time we did not get any updates of your car.
Anyways i wanna ask you 2 questions please:
1- Can I send you My ECU so you do me your customs remap for the K04-001? I know that you prefer to have the car to put it on a RR session but I am on a dead end road now, and when I get back the ECU i will do a fine tuning on a RR session here, can this be done?
2- Do you prefer if I get a Forge Actuator for my Turbo? and which spring should I get?
thank you in advance mate,
Offline golf-sib
  • Турботазик
« Reply #56 on: 21 November 2011, 12:50 »
Hi Nick,
If its a k03s then forge actuator and blue spring would be recommended
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Dave_IOW
« Reply #57 on: 21 November 2011, 14:12 »
Hi Nick,
KO4-001 i pressume bud  :undecided:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline raptorSE
« Reply #58 on: 21 November 2011, 14:13 »
Thats gonna be a beast. My MG ZR Turbo was running 261bhp and 238 ft/lb torque and that done a 13.1 and that was proper quick  :cool:
Seat Leon Cupra R
Offline LEBMK4GTI
« Reply #59 on: 21 November 2011, 15:03 »
Hi Nick,
My turbo is a K04-001 and not a K03s.
« Last Edit: 21 November 2011, 15:05 by LEBMK4GTI »
