Author Topic: need help with my mk4 2.0lt gti HELP  (Read 1259 times)
Offline jripper
« on: 11 May 2011, 11:24 »
hi i dont know if anyone can help me but my gti 2.0  is running like a sack of s**T . when i turn it on the rev go up and down it never ticks over in one spot it also cuts out when i stop to give way  .
started with a new fan belt and cos the check light was on i was told to get a new mass air flow.
i put the new one on and it was running good for a couple of weeks then it just cut out on me so i had to pull the cable off the mass air flow to get home  and it seems to tick over ok .
went and got another one but its doing the same thing
before this problem i had a new water pump put on by a so called Mechanic. dont know if he would of had to take the timing belt off to do the job but if he did could it be a timing problem.
« Last Edit: 11 May 2011, 11:26 by jripper »
Offline sharki786
  • GOT BOOST??
Re: need help with my mk4 2.0lt gti HELP
« Reply #1 on: 11 May 2011, 13:38 »
think you need to remove the timing belt to change the water pump. correct me if im wrong. best bet is get vag-com onto it and you will get more information
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #2 on: 11 May 2011, 16:29 »
Get it scanned for codes as a 1st step.
Offline Dannyavw
« Reply #3 on: 13 May 2011, 21:39 »
I'm an ex Vw technician and you do have to remove cambelt to access waterpump
