Author Topic: DPF'd TDI Remaps  (Read 16798 times)
Offline Rhyso
DPF'd TDI Remaps
« on: 11 May 2011, 10:10 »
As some you know my Aldi has the 170 PD TDI engine fitted with that wondrous invention called the DPF (diesel particulate filter)
After nearly a year of ownership its time to start looking in getting more power out of the engine......
Looking around very few companies offer anything for the engine due to its well known problems with DPF's and the associated sensors failing.
Anyone got any suggestions??  If you do DO NOT recommend Custom Code to me.  Been there, done that  :lipsrsealed:
Ta  :smiley:
EDIT - meant to add that I'm just looking for a remap intially as there seems to be some confusion over whether or not it will be a legal requirement to have the DPF in place; though my understanding is you can't enforce MOT changes on older cars, only newer ones??  :undecided:
« Last Edit: 11 May 2011, 10:19 by Rhyso »
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: DPF'd TDI Remaps
« Reply #1 on: 11 May 2011, 13:59 »
We can offer the DPF mapping, which means the ecu comes out to read the full code areas, the map will go back on the the ecu with a patch which changes the DPF regen settings and a higher dct offset for the front and back pressues sensor thresholds. Once the ecu have been mapped and patched you can then run the car with out the DPF filter, with 2 options 1) use the oem dpf pipes and remove the filter core, or 2) get a bespoke DPF delete system and sell your house.
Even on the stock mapping there are many cases of DPF issues, VW even detuned some of the early 170TDi to arounf 150bhp via a software update to stop all the warranty claims realted to DPF.
I just been on the MoT tester PC:
The only way a car will fail is (TDI) that the smoke test reading is over 3.00m2, or there is visual dense blue or black smoke for all car 1979 onwards.  Nothing in the current MOT guide lines about cars with DPF or CATs, but there is talk of new MOT emission regs next year, maybe a lower threshold of 2.00m2 or 2.5m2 or/ and viusal inspection of oem cat or DPF.  Which means if your mot tester aint a c@ck your car will pass every MOT.
 01455 617233
Offline Rhyso
« Reply #2 on: 11 May 2011, 14:44 »
Howdy
What do you reckon is the best way forward?? Gutting the DPF or getting the Milltek delete pipe??  :undecided:
I've read about the engine being tuned but from what I can gather its detuned in 1st and 2nd gears and re-programmed to regenerate the DPF more often  :undecided:
Have you had any 170's on the rollers after the update from VW / Audi?
Thanks for the info on the MOT  :nerd:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 11 May 2011, 15:14 »
Surely buying the delete pipe would be better no ??
Offline Rhyso
« Reply #4 on: 11 May 2011, 15:16 »
That's what I'm asking...... :rolleyes:
I've heard two sides of the coin
Offline RTechUK
« Reply #5 on: 11 May 2011, 17:01 »
Hello,
We have been refusing to tune all VAG with DPF systems fitted, we have done many BMW with out issues, but VAG because of all the issues we have decided to steer well away. Even with the tuners so called DPF fault mapping out there is still many customer having costly DPF issues.
The problem with the DPF delete is one price, then if the MOT law changes and the test include visaul inspections then you could fail.
Gut it  :wink:
Nick
 01455 617233
Offline Carbon-Chiptuning
  • Carbon Chiptuning
« Reply #6 on: 14 May 2011, 13:06 »
Hi,
We recommend That you swap your DPF for a bypass pipe, this is because if legislation changes to more than a visual inspection you will be snookered as the contents of your DPF will be at the bottom of a landfill site.
The bypass pipes cost between £210 and £400, if you have a car that we can't buy an off the shelf item for we have an exceptionally gifted exhaust contractor that will make you a truly custom DPF bypass pipe. The cost would be between £80 to £400, the cost for removing your old DPF and fitting your new one by our contractor is around £50.
We can also have your DPF insides knocked out one of our local contractors if you're not concerned about the above of course at a cost of around £100 including the removal and reinstall.
Once the DPF is removed the car should see 210 bhp and 325 lbft of torque, the cost is for the mapping including the DPF remove is £375 less our current introductory forum discount of £100 plus a £10 donation to the site so total software cost is £285.
Regards
Craig
Modified to make it a little easier to read, damn this iPad  :grin:
« Last Edit: 15 May 2011, 07:54 by Carbon-Chiptuning »
Carbon Chiptuning
Intelligent Solutions
mobile: 07825 215003
freefone: 08000 435 997
email: nick@carbonst.com
web: www.carbon-chiptuning.co.uk
Offline richw911
« Reply #7 on: 14 May 2011, 21:13 »
Hi,
We recommend That you swap your DPF for a bypass pipe, this is because if legislation changes to more than a visual inspection you will be snookered as the contents of your DPF will be at the bottom of a landfill site.  The bypass pipes cost between £210 and £400, if you have a car that needed we have an exceptionally gifted exhaust maker that will make you a truly custom DPF bypass pipe, the cost for removing your old DPF is around £50.
Once the DPF is removed the car should see 210 bhp and 325 lbft of torque, the cost is for the mapping including the DPF remove is £375 less our current introductory forum discount of £100.
Regards
Craig
Interesting stuff  :nerd:
Hurry up Rhys  :laugh: :laugh: :laugh:
Offline Adam
« Reply #8 on: 14 May 2011, 21:22 »
Hi,
Regards
Craig
:evil:
Down Hill From Here.
Offline JC
  • Back in the North.
« Reply #9 on: 14 May 2011, 21:22 »
Hi,
Regards
Craig
Needs to save up first, and read his PM's too  :lipsrsealed: :kiss:
