Author Topic: DPF'd TDI Remaps  (Read 16770 times)
Offline Rhyso
Re: DPF'd TDI Remaps
« Reply #20 on: 07 July 2011, 21:55 »
sorry to bring up an old thread but im looking at getting a 170 Octavia Vrs, is it best to not bother with a remap then? kinda got lost reading about bypass pipes and DPF's  :laugh:
Done 1200 miles on mine now and so far no problems to report............
Ideal  :cool: Goes like fook eh?  :evil:
Lets say she makes progress.............. :evil:
Spin please on next meet  :evil:
Get your backside to Castle Combe next weekend then  :tongue:
Offline richw911
« Reply #21 on: 07 July 2011, 21:57 »
Ah is that next week  :shocked: i may be free....... :evil:
Offline Rhyso
« Reply #22 on: 07 July 2011, 22:06 »
Well your name is on the stand list now so you better show up  :tongue: :wink: :grin: :grin:
Offline richw911
« Reply #23 on: 07 July 2011, 22:08 »
I will be there :afro:
Offline Rhyso
« Reply #24 on: 07 July 2011, 22:11 »
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #25 on: 15 July 2011, 18:43 »
It's always worth mapping these cars and we can offer a solution tailored to your needs with or without a DPF delete pipe.
What engine are you looking for CR or PD and approx age?
Offline irmscher
  • Mobile Engine Tuning www.premiertuning.com
« Reply #26 on: 15 July 2011, 20:55 »
If the DPF is healthy and regenerating without issue then you can leave the DPF ON and tune it within the regen cycle capabilities... if its weak and as long as there are no ECU errors for DPF (this bit is key as the errors are logged in a seperate part of the ECU and notoriously difficult to remove once the DPF fails) then you can remove DPF, install a bypass pipe and successfully map out the DPF, EGT sensors etc and make better power.
If you're installing a bypass pipe, ensure it's a decent quality item with flange connectors.  I've seen everything from chop shop rubbish to some numpty even 'smashing' his DPF through (and destroying the EGT sensor in the process, and pushing the crap back into the turbo)!!
If you're going to do something like this, do it right first time.
« Last Edit: 15 July 2011, 23:49 by irmscher »
Mobile Engine Chiptuning & Remapping Specialists
Cars tuned from £199 at base
info@premiertuning.com or Facebook
Offline Rhyso
« Reply #27 on: 22 July 2011, 21:55 »
Results with the DPF firmly in place
Offline The Doc
« Reply #28 on: 22 July 2011, 23:56 »
Where it's staying too  :wink:
Offline Rhyso
« Reply #29 on: 03 October 2011, 08:19 »
Is it??  :tongue:
