Author Topic: replacement rear discs  (Read 2622 times)
Offline lewis1641
  • stuck in the 90's
« on: 09 May 2011, 15:19 »
just received these...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=370350076989&ssPageName=STRK:MEWNX:IT
and they are clearly front discs. have the counter sink for the screw that attaches them to the hubs and nowhere for the bearings to press into. i have emailed them but no reply. have also just noticed that they are 239mm so very sure these are driver fronts (they are solid).
or am i wrong? did any golfs come with 239mm rear discs that screw onto a seperate hub?
« Last Edit: 10 May 2011, 13:28 by lewis1641 »
Offline cняis
Re: re3placement rear discs
« Reply #1 on: 09 May 2011, 20:22 »
No
Even mk3 rear discs are the same fitment
You have front ones son!
Offline lewis1641
  • stuck in the 90's
« Reply #2 on: 09 May 2011, 23:18 »
grr. they are suggesting they will accept them back and supply the right ones, but the right ones are nearly double the price!
if they dont take these back i could always use them on the wife's mk3 diesel (if it EVER runs again...)
Offline Simeon
« Reply #3 on: 10 May 2011, 01:16 »
The listing is for a Rallye so are suitable for the syncro .. prob correct rears in this case.
« Reply #4 on: 10 May 2011, 09:27 »
I believe as above Syncro rears were different so they might be correct in that case, however will be wrong for a standard mk2.
Offline mwep201081
« Reply #5 on: 10 May 2011, 12:24 »
What wrong with the Mrs's Mk3? If it's a 1.9 TD I'll take it off your hands if you like :wink:
Offline lewis1641
  • stuck in the 90's
Re: replacement rear discs
« Reply #6 on: 10 May 2011, 13:29 »
it is non turbo. wont start (suspect starter motor)
if you saw it you probably wouldnt want it!
Offline mwep201081
« Reply #7 on: 10 May 2011, 15:19 »
Nice...I'm after a 1.9 TD for my camper.....don't want to pay ebay prices tho...(£300 +)
Offline dan_apps
  • too low for british roads!
« Reply #8 on: 10 May 2011, 20:33 »
love the teeth and airplane grey!
Offline Sam
  • Sam I am
« Reply #9 on: 10 May 2011, 20:35 »
Somhow its not as neat in real life  :grin: :grin:
