Author Topic: VR6 obd2 Engine idle/acceleration response issue  (Read 1604 times)
Offline AdamMk2
  • Beautiful
Hi All,
My mates OBD2 vr6 has been playing up something terrible the last week or so,
Basically its not idling properly, so struggling, when you leave the engine on it basically cuts out before the ecu must stop it then shoots the revs back up to 1000rpm but does then finally die
Acceleration is non existant, theres no response what so ever and when it does finally catch up its so underpowered
The engine was rebuilt a little while back now, since this problem has developed we have changed the following
ECU Relay
Fuel pump relay
Fuel filter
Plugs
Leads
Coilpack
The lamba was fitted not long ago now, it does have a custom exhaust on it straight through, so my only concern is its sooted up the lamba.
Does anyone have any other possible ideas please?
Thanks
AD
« Last Edit: 08 May 2011, 09:48 by AdamMk2 »
Offline forsh
Re: VR6 obd2 Engine idle/acceleration response issue
« Reply #1 on: 08 May 2011, 10:12 »
clean throttle body
check maf sensor
Offline AdamMk2
  • Beautiful
« Reply #2 on: 08 May 2011, 10:32 »
clean throttle body
check maf sensor
Forgot to say did those too mate :(
Unplugged the maf and gave the throttle body a good clean round what I could get too
 :undecided:
Offline cняis
« Reply #3 on: 08 May 2011, 10:35 »
i doubt its a lambda issue, mine was mounted in such a way it wasnt analysing the exhaust gasses so might aswell have been disconnected. The car drove fine but used loads of fuel and failed MOT emissions test.
Have you compression tested it?
Offline forsh
« Reply #4 on: 08 May 2011, 10:36 »
did you check the vacum hose on the fuel regulator
also is the crank shaft breather pipe split or blocked in any way
maybe a rad hose is blocked or not block but not flowing to well
« Reply #5 on: 09 May 2011, 09:25 »
I would get it compression tested as the next step.
Offline AdamMk2
  • Beautiful
« Reply #6 on: 09 May 2011, 22:59 »
Hvent had chance to get it tested yet unfortunately as its worked on by the phirm so hes adement on taking it back there lol,
thing is, if you disconnect the bttery for ten, then plug it back on it works fine for a while, Im thinking sensor and fault codes or a bust ecu :/
who knows eh but thanks for your replies everyone
Offline dashey
« Reply #7 on: 11 May 2011, 02:25 »
Mine idled fine but was underpowered like you said turnt out to be cam position sensor i Got one for a fiver and it sorted it so no harm in trying
