Author Topic: TPMS - Retro-Install - final stages - HELP!  (Read 2833 times)
Offline Buck
  • Das Auto
« on: 07 May 2011, 11:28 »
Hi guys
finally got round to installing the above (loom provided by SteveP)
I have the yellow wire through the bulkhead grommet and now need to fasten the pin into the ABS controller behind the battery - which I have removed after taking the battery out - so far so good.
In the instructions it says to unlock the connector using a screwdriver - I have done this but then what?
How do I gain access to the rear of the connector block to insert the new cable into 35 pin? or am I missing something?
Car is currently "disabled" whilst I work this out so any help appreciated!
Thanks
« Last Edit: 08 May 2011, 09:41 by Buck »
Offline mike.
Re: TPMS - REtro-Install - final stages - HELP!
« Reply #1 on: 07 May 2011, 11:31 »
You need to unclip the backshell from the connector to enable you to push the wire in from that side..
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Buck
  • Das Auto
« Reply #2 on: 07 May 2011, 11:32 »
It's this bit where I've got myself stuck!
I've unlcoked the connector but without breaking the housing what do I do to get access?
Offline Buck
  • Das Auto
« Reply #3 on: 07 May 2011, 11:33 »
Thanks Mike
I can see a hole for the wire with a rubber bung/plug in it - just remove this? then slide the wire through?
Offline mike.
« Reply #4 on: 07 May 2011, 11:35 »
Yes, you can use a cocktail stick or something like that to push it out from the other side.
Offline Buck
  • Das Auto
« Reply #5 on: 07 May 2011, 11:36 »
Good man!
Off back down to the garage to have another go - will be back to update in a while  :cool:
Offline Buck
  • Das Auto
« Reply #6 on: 07 May 2011, 12:21 »
Thanks Mike
Wire in, connector back on etc. Just to code now when I get access to VCDS.
Adrian
Offline mike.
« Reply #7 on: 07 May 2011, 12:30 »
Great stuff Adrian, glad to be of help  :smiley:
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #8 on: 07 May 2011, 12:37 »
Any chance of some photos as i have mine to do at some point too and the more info the better really.
« Last Edit: 07 May 2011, 14:41 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Buck
  • Das Auto
« Reply #9 on: 07 May 2011, 14:24 »
Geoff
I've fully reassembled mine now but if I can get some shots and words to support Steve's guid I will do.
Adrian
