Author Topic: wash wipes stoped working  (Read 4737 times)
Offline nicksvw
« on: 06 May 2011, 20:26 »
Hi as it says really took car for mot and the wash wiper as stoped working.Thought it was the pump but that workswhen connected to battery.plz help .
Offline matping
  • MK1 20vT MK5 GTI T
Re: wash wipes stoped working
« Reply #1 on: 06 May 2011, 20:38 »
whats happening bud you press the washers and they dont wash the windows but youve tested the motor and it works?
Offline nicksvw
« Reply #2 on: 06 May 2011, 21:20 »
yes mate was wipers and no water now no wipers or water on wash wipe mode lol
Offline matping
« Reply #3 on: 06 May 2011, 21:31 »
have you checked the fuse ? start with the fuses  if ok then multimeter on the wiper motor wires
the washer motor do you hear it  when you press the washer switch
Offline nicksvw
« Reply #4 on: 06 May 2011, 21:33 »
which fuse is it??
Offline matping
« Last Edit: 06 May 2011, 21:50 by matping »
Offline nicksvw
« Reply #6 on: 06 May 2011, 21:55 »
The wipers work but not when you pull the stalk back to activate the wash wipe  only when you move it up to spedd 1 and speed 2
Offline matping
« Reply #7 on: 06 May 2011, 21:57 »
sounds like the contact has broken inside the switch
Offline Guy
« Reply #8 on: 06 May 2011, 22:49 »
mine failed its MOT on this.. try cleaning the connection to the bottle.. bit of sandpaper to clean off the crap a bit did the trick
Offline JC
  • Back in the North.
« Reply #9 on: 07 May 2011, 09:17 »
 :lipsrsealed:
