Author Topic: The "Genuine" Mk2 front wings thread...  (Read 44659 times)
Offline Thom89
  • Looking for an "Icebreaker"
Re: The "Genuine" Mk2 front wings thread...
« Reply #30 on: 14 May 2011, 22:23 »
So, fitted the said wing today, and it has to be said that fitment is superb, probably due to the closing panel at the rear of the wing now being positioned in the correct place (See my first post for explanation) the important thing is that the wing can be fitted without having to force anything into submission, the panel itself though will require plenty of work to get perfectly straight, and ripple free, but thats a different story
This first pic shows the upper swage line close to where the flasher repeater fits, note how the swage has lost its definiton, compared to the swage on the door, this is due to worn out tooling in the factory, god knows how many millions of these things were stamped out!
2nd pic shows the wing fitted (not permanently) and an even gap top to bottom, top swage lines up nicely, but the lower one appears to be out of line by a couple of mm, this is because the wing has a very slight bow to it down the rear edge, placing the wing on the floor, and gently applying a little pressure to the panel will sort this out. Also notice that the reflection of the florescent light runs through the door, and carries on in the same direction as it passes through the wing, thats something you rarely get when fitting pattern parts
When the wing get its final fit, the car will be sitting on it wheels on a level floor, with the strut brace slackened off, just to make sure that the shell is under no stress  whatsoever...
Thom
« Last Edit: 14 May 2011, 22:26 by thom89 »
Offline jv
  • Administrator
« Reply #31 on: 15 May 2011, 00:38 »
:nerd:
that's all right now.
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #32 on: 15 May 2011, 10:24 »
That looks really good mate.. Have you had to trim much off of that wing to get it how it sits at the moment ??
Offline beechymonza
  • mad beech
« Reply #33 on: 15 May 2011, 10:44 »
I just picked up a genuine door and 2 wings for 20 quid,  :cool:
No guts No glory,
Offline Thom89
« Reply #34 on: 15 May 2011, 14:51 »
I've trimmed nothing off it... interestingly though, the OE wing that the car came out the factory with, didn't fit the way it should have,
because the closing panel was welded in the wrong place, the car itself is a very late model, and pretty much all the existing panels are showing the telltale signs of worn tooling
Will be doing a build thread on this in a month or so, with the owners permission :lipsrsealed:
Thom
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #35 on: 15 May 2011, 15:15 »
Well i want to buy 2 new front wings for mine.. but... I dont like the fact the swage lines are more rounded.. they are very noticeable in them pics is it that bad in real life ??
Offline Thom89
« Reply #36 on: 15 May 2011, 15:49 »
That top pic was taken VERY close, and door gap looks wide, in fact its a little over the width of a pound coin! the wing that this new wing is replacing, was, as I've already said, the OE factory fit wing, that also is displaying the same rounded swages, and extra radius to the rear edge, a little careful hammer and dolly work will soon have this literally better than new, I must emphasise  though that these wings are miles better than any pattern part you could ever buy, but, I'm quite fussy about how I like things to fit.
These wings could be given 4/5 coats of Hi build primer, block sanded, fitted and painted with no problem they're that good :cool:
Thom
« Last Edit: 15 May 2011, 15:53 by thom89 »
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #37 on: 15 May 2011, 16:00 »
Thanks for that info Thom will have to get a couple of wings when moneys a bit better.. I can fit G60 arch covers for a standard wing fine cant i ?? Sorry for 21 questions lol  :smiley:
Offline Thom89
« Reply #38 on: 15 May 2011, 16:34 »
I'm sure you can fit G60 arches as discussed elsewhere in this thread, could do with someone putting up some pics for reference of some genuine G60 wings.... anyone?
Thom
Offline Organisys
  • Old and Slow...
« Reply #39 on: 16 May 2011, 14:09 »
Fitment looks good, but like you said...the swage ! wow.
 :smiley:
