Author Topic: mk2 vr6  (Read 4587 times)
Offline chippy3
mk2 vr6
« on: 04 May 2011, 20:00 »
im going to be looking at a mk2 golf with a vr6 engine. im going with my uncle who is mechanic, but id jus like a basic heads up, what to look out for
cheers
Offline Neo Badness
  • Feet are for pedals
Re: mk2 vr6
« Reply #1 on: 04 May 2011, 20:39 »
rust on body and a sh!tty engine install. Buyers guide on here should help
Offline cняis
Re: mk2 vr6
« Reply #2 on: 04 May 2011, 21:57 »
Dodgy wiring is number 1. have a poke around the fuse box!!!!!!
Also check the front cross member, is it a welded mk3/mk2 combo, a corrado VR6 one or a standard mk2 one with a conversion mount? If its mk3/mk2 combo check the quality of the welding. You dont want you're engine falling out.
Offline Diamond Hell
  • Opinions я Us
Re: mk2 vr6
« Reply #3 on: 04 May 2011, 22:06 »
Surely this should be referred to as 'dropping anchor'?
Re: mk2 vr6
« Reply #4 on: 04 May 2011, 22:08 »
Main things are to check the quality of the conversion and standard of wiring.
Offline Thom89
  • Looking for an "Icebreaker"
Re: mk2 vr6
« Reply #5 on: 04 May 2011, 22:38 »
How much is the seller asking?
Thom
Offline cняis
Re: mk2 vr6
« Reply #6 on: 05 May 2011, 00:08 »
Thom
[/quote
Anywhere between 1.5k and 3k is about right depending on the quality of the work.
Offline chippy3
Re: mk2 vr6
« Reply #7 on: 06 May 2011, 17:55 »
thanx for the advice guys
and thom, hes askin 1000 for it :)
Offline chippy3
Re: mk2 vr6
« Reply #8 on: 06 May 2011, 17:59 »
and its also a 3 dr in a  J reg shell
Offline Mr Blue
Re: mk2 vr6
« Reply #9 on: 06 May 2011, 18:08 »
for £1000 i would worry about the wiring last. If the engine runs then bonus!
Look in the buying guide for general tips but I always look at the condition of the bodywork/sills.
Cam chains on the vr6 can rattle. Had 2 vr6's with rattling chains and was a gearbox off job :sad:
