Author Topic: mk2 vr6  (Read 4588 times)
Offline chippy3
Re: mk2 vr6
« Reply #10 on: 06 May 2011, 18:21 »
Offline madmanluke
Re: mk2 vr6
« Reply #11 on: 06 May 2011, 19:53 »
Id say go for it. Vr's are solid engines and usually wont let go unless its had some real abuse. chains and tensioners as mentioned if you can be bothered. The price of the engines now days to me makes it hardly worth the effort. If it detonates, go and buy another block for 3/4 the price and lob it back in.
most wiring problems are fairly easy to fix. Just look at the quality as to how its been done. Does it looks like its just been lashed in there or someone has actualy thought about what they are doing?
Offline cняis
Re: mk2 vr6
« Reply #12 on: 06 May 2011, 19:55 »
Which brake setup is the car using?
Has the motor been slapped in without uprating the fronts?
Offline Neo Badness
  • Feet are for pedals
Re: mk2 vr6
« Reply #13 on: 06 May 2011, 20:26 »
2 sets of plug leads?
Usual rules of buying a car apply if it's solid then go for it. Engines and wires can be replaced or repaired. Bodywork is far more involved. Trust me, I know.
Is it 5 stud or 4 stud? Hopefully it'll have the 5 stud 288mm brake setup and full cable change setup.
Offline madmanluke
Re: mk2 vr6
« Reply #14 on: 06 May 2011, 20:41 »
Another thing. Clutch - hydraulic or cable change.  If its cable - that might be something you might want to change in the future.
Offline Neo Badness
Re: mk2 vr6
« Reply #15 on: 06 May 2011, 21:04 »
Cable change is hydraulic in my mind and rod change is the non hydraulic. But hopefully basically it'll be either a mk3 vr 2.8 from bumper to back of dash. Or even better it'll be corrado 2.9 :evil:
Offline cняis
Re: mk2 vr6
« Reply #16 on: 07 May 2011, 13:55 »
Im not sure you can use a rod-change setup... Normally a mk3 gear changer (cable type) is mounted in the tunnel which is a simple job.
Regards cable/hydraulic clutch, there's nothing wrong with cable as its not heavy (mine is light enough) and there's no issues with cutting up the firewall unlike using a hydraulic pedal box.
It does have 2 rows of 3 cylinders you know  :grin:
Offline Neo Badness
Re: mk2 vr6
« Reply #17 on: 07 May 2011, 17:43 »
Reeeeeeally? I didn't know that. 2 rows of cylinders eh? Fancy that.  :tongue:
I meant that they were different colours. In that if they had been tight and only replacing 3 at a time rather than a set it may mean they have skimped on servicing.
Offline cняis
Re: mk2 vr6
« Reply #18 on: 07 May 2011, 19:35 »
True dat. Its strange as I havent seen any half sets for sale?
Offline Neo Badness
Re: mk2 vr6
« Reply #19 on: 07 May 2011, 21:26 »
Me neither but could be innocent enough, just the first thing I noticed in the pic. Would be giving it a good look over and factor that into the pricing. Mind you, for a bag of sand and most of the hard work is done you can't argue really.
Even if worst case engine goes pop my mate just picked up a known good 2.8 vr on the subframe with g/box etc for 150, bonkers :shocked:
