Author Topic: clutch slip  (Read 2883 times)
Offline R32UK
clutch slip
« on: 04 May 2011, 08:20 »
Anyone else get lots of clutch slip on full throttle???  :undecided:
problem after fecking problem  :embarassed:
Offline Keithuk
Re: clutch slip
« Reply #1 on: 04 May 2011, 12:21 »
It looks like you need a new clutch, whats the mileage?
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline SteveP
Re: clutch slip
« Reply #2 on: 04 May 2011, 12:39 »
Mapped TSI's produce a lot of torque, I know a lot of Rocco owners that have had to uprate their clutches.
Re: clutch slip
« Reply #3 on: 04 May 2011, 14:38 »
I'm never quite sure whether my GTI has a touch of clutch slip occasionally or it's the dreaded REVO hesitation. I don't use it enough to think about getting it investigated but it definately drives a bit funny from time to time when 'moving on' at certain mid range revs.
‘23 Leccy Mini, ‘25 8.5R, ‘23 8R, ‘20 8CS, ‘19 135iX, ‘19 TCR, ‘17 Ed40, ‘17 GTD, ‘15 7R, ‘13 GTI PP, ‘11 GTI, ‘09 GTI, ‘98 Ibiza Cupra, ‘05 GTI, ‘06 Polo GTI, ‘04 GT TDI, ‘05 Fabia vRS, ‘02 GTI T, ‘03 Ibiza TDI 130, ‘01 Leon 180, ‘89 mk2 16v, ‘99 Ibiza TDI, ‘96 VR6, ‘98 Ibiza TDI, ‘92 VR6, ‘88 mk2 8v, ‘92 Polo G40, ‘91 mk2 8v, ‘89 mk2 8v, 205 GTI 1.9, ‘83 mk1 GTI, ‘80 Scirocco GTI, plus some others I’ve forgotten
Offline am1w
Re: clutch slip
« Reply #4 on: 04 May 2011, 16:35 »
Gilly, your clutch is about to meet its maker. RIP.  :cry:
Offline Keithuk
Re: clutch slip
« Reply #5 on: 04 May 2011, 22:49 »
So you don't know the difference between clutch slip or a hesitation?
Offline am1w
Re: clutch slip
« Reply #6 on: 04 May 2011, 23:18 »
Quote from: Exonian on Today at 14:38
Quote from Keith: So you don't know the difference between clutch slip or a hesitation?
I am sure Andy does, but he just felt it would be a giggle to feign ignorance and to crow he has a very fast petrol car which happens to be the  GTI! :smiley:
Re: clutch slip
« Reply #7 on: 05 May 2011, 04:59 »
Thank you for your support Asker but alas no.
On this occasion I have no idea whether the car has slight clutch slip or a slight hesitation very briefly under heavy load in certain gears at certain revs.
I don't use the car often enough to familiarise myself with exactly when it occurs and am too busy doing stuff to the house at the moment to take the car out and investigate properly, so I can genuinely sit here and look stupid and ignorant!
I've had modified TDIs in the past which have had genuine clutch slip at peak torque in the higher gears. Easily corrected with a tweak of the map to smooth the torque out and lower the peak figure (basically they wind back the fuelling and boost at certain revs). No new clutch needed.
I've had turbo petrols in the past which have had hesitations, possibly map related or maybe good old diverter valve leaks or stutters. Again, easily cured.
This one is a mystery though as it only happens occasionally when I'm overtaking. Thus the car is accelerating quickly, gear change, quick stutter and revs normally again.
I'm concentrating 100% on the road conditions at the time and not sat looking lazily at the rev counter to see if the revs actually briefly stall (REVO hesitation) or the speedo briefly stalls and the revs rise (clutch slip). By the time my eyes have moved from scanning the road conditions to the rev counter it's returned to normal and all hell has broken loose at the front wheels, torque steer has started and 100% concentration is needed for the job in hand again. Seconds later I'm at a legal cruising speed, the moment has passed and thus put to the back of my mind again as I concentrate on my driving. So no, I don't know whether it is one or the other problem. I'll investigate it when I have the time and motivation. It's not dangerous so low priority. Could even be a leaking DV under full boost.
When the car was rolling roaded 18 months ago it was putting out almost exactly 300 lb ft on TSRs rollers.
Offline R32UK
Re: clutch slip
« Reply #8 on: 05 May 2011, 07:37 »
Cheers Steve!  :smiley:
I am pretty sure its clutch slip. Even my passenger noticed it the other day.... i have kind of grown used to it. Time to get her back on the rollers and sort these little issues out :undecided:
