Author Topic: Caliper Tool  (Read 1680 times)
Offline leegt5
Caliper Tool
« on: 03 May 2011, 21:58 »
Gonna be doing the rear discs and pads.. Understand its a pain without the push back tool... Will this one do ?
http://www.amazon.co.uk/Laser-Brake-Caliper-Piston-Re-wind/dp/B002V72SHS/ref=cm_cr_pr_pb_t
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Caliper Tool
« Reply #1 on: 03 May 2011, 23:02 »
yep, should be fine.
Offline freezaburn
Re: Caliper Tool
« Reply #2 on: 04 May 2011, 14:48 »
I find that a circlip plier or even a diamond-nosed plier can get the job done! :grin:
Offline danmusic24
Re: Caliper Tool
« Reply #3 on: 04 May 2011, 15:29 »
use the tool for the job! i found out the hard way....but easy with rewind tool :smiley:
Re: Caliper Tool
« Reply #4 on: 04 May 2011, 15:59 »
Yep will do the job all ok.
Offline ju571n
Re: Caliper Tool
« Reply #5 on: 04 May 2011, 16:09 »
Slip joint pliers   :grin: :grin:
Failing that.. Stilsons  :cool:
Offline Dmonday
Re: Caliper Tool
« Reply #6 on: 04 May 2011, 16:15 »
I jumped on a spade while holding on a fence, worked fine :)
Offline leegt5
Re: Caliper Tool
« Reply #7 on: 04 May 2011, 19:07 »
Never done rear discs on a mk3 Golf. My old ABS ring can I reuse it and what is it attached to ?
Offline leegt5
Re: Caliper Tool
« Reply #8 on: 12 May 2011, 22:57 »
I Know now that I can use my old abs ring and how its attached...
Looking at caliper tools..
Can I use this ?
http://www.eurocarparts.com/ecp/p/tools/car-service-tools/brake-service-tools/brake-system-tools/?SEAVS039&0&t5_390
Re: Caliper Tool
« Reply #9 on: 12 May 2011, 23:04 »
You can but Im not a fan of them tbh as if the piston is slightly seized or even tight then you need to be putting quite a bit of force into trying to push the piston back whilst attempting to wind the bugger back on the ratchet.
At least with an actual wind back tool they have a plate that sits inside the caliper in-place of the pads that forces against itself whilst threading outwards to push the piston back / open. Much easier to use in my opinion.
