Author Topic: abs pump fitment 8v-16v ??? will it work? both 288mm set up  (Read 1719 times)
Offline dragongreengolfgti
  • my golf gti mk3
Right people need a little advice i have a vag-com code on my 97 r reg 16v abf, which is 01276. After using the SEARCH option on here i know theres a problem with the abs pump!  :sad: Although this could be fuse related i havn't checked yet because i broke my wrist 3 weeks ago and cant do sod all  :cry:
Anyway all i want to know really is i have a 96 p reg 8v with the same 288mm brake set up which looks very similar indeed. So will the pump and unit underneath be the same do you think? Has anyone other than the ones ive read on the search options had this error and know of any other small fixes it could be ?
Just to let you know i have an error code for every speed sensor on each wheel aswell, which i can only assume is because the pump isn't working? definately have no abs and need this sorted asap  :wink: The brakes are very good however with up rated vented disks and green stuff pads all round they just lock up under heavy braking  :sad:
All the same I believe, just check the part number if not sure.
  • my golf gti mk3
nice finally a reply lol i kind of thought they could be the same if i hadn't of done my wrist in few weeks ago i'd have it off by now  :cry: think i'l try and find the part number on both tomorrow if i can get at it  :smiley: cheers mate
No problems, cannot see there being any difference between 8v and 16v.
 :smiley:
Offline boneybradley
  • Back in a Mk3...
I have checked my sources and it does list a different pump between the 8 and 16v models due to the 16v having t.c.s
The listing isn't 100% clear so double check the part numbers as my russian isn't that good so I may of got lost in translation!  :grin: (I think 8v ends in 117 and the 16v as 217)
Offline neil1780
1H2 698 117 is abs
1H2 698 217 is abs+eds
V6 4MOTION
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
I was also under the impression that the 16v shared the same one as the VR6 which is slightly different to the 8v?
  • my golf gti mk3
Ah ok then so it may not be possible after all  :sad: but still worth a look just in case  :smiley: cheers guys one way or another i'l need them part numbers  :cool: may have to source a proper 16v which shouldn't be a problem on here  :smiley: i'm just hoping the 8v would fit as im breaking two 8's at the mo and would save me some penny's  :grin:
id be checking the part numbers on them before spending any money for sure.
  • my golf gti mk3
Alright guys well update i have checked my 16v part number being 1H2 614 217 D and my 8v being 1H2 614 117 C so i take it this is no good because of the difference in 217 D and 117 C  :sad:
Anyway seen this on ebay http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170628022035&ssPageName=STRK:MEWAX:IT he saids in his ad it will fit all including vr6 etc but i think hes telling porkies  :grin: definately need one as ive checked every other thing so far  :sad: what do you think?
