Author Topic: 1.6 to 1.8gti 8v conversion help  (Read 7533 times)
Offline kennedy
« on: 03 May 2011, 13:49 »
Hi,
i have myself a 1990 1.6 driver and the engine is on its way out, picked myself up a digifant 1.8gti 8v engine for a bargain of a 100 from my friends mk2, i was just wondering if its a straight swap (looks it) and if id need the ecu and loom to wire the gti engine up or will my loom do the trick?
thanks
Offline lemski
  • 16v
Re: 1.6 to 1.8gti 8v conversion help
« Reply #1 on: 03 May 2011, 14:16 »
Gti loom unless ur off to carbs mate. Also undercar fuel pump and loom for that
« Reply #2 on: 03 May 2011, 20:29 »
Gti loom and ecu, fuel pumps and lines are also needed I believe the tank is the same.
Offline lemski
  • 16v
« Reply #3 on: 03 May 2011, 20:31 »
Ahh yes fuel tank. I changed the intank liftpump in mine cos the connector was differant but then i went from post 90 wiring to pre 90 and had to swap most of my looms
Offline kennedy
« Reply #4 on: 04 May 2011, 15:52 »
Thanks for the info, big help!, so fuelpump + lines, ecu + loom? both engines are 1990
on the hunt for the parts now
« Reply #5 on: 04 May 2011, 15:54 »
Also don't forget to look at uprating the brakes.
Offline kennedy
« Reply #6 on: 04 May 2011, 16:02 »
ah yeah was gna get me a set of fresh pads and grooved discs, or would you recommend upscaling them?
« Reply #7 on: 04 May 2011, 16:14 »
If they are vented they will be fine, just make sure they all work ok.
Offline lemski
  • 16v
« Reply #9 on: 05 May 2011, 12:48 »
If the 8v is digi then 16v looms wrong as there all k-jets. Best bet is find someone who's breaking a 1.8 gti and get all the stuff of them. Make sure its the right wiring. Pre or post 90. Pre 90 is 2pin clocks and post 90 is single clocks.
