Author Topic: Service Advice  (Read 1720 times)
Offline WadGTI
  • Golf GTI'er
Service Advice
« on: 03 May 2011, 10:57 »
Hi Guys,
Just about to get the golf running, however it has not been started for nearly 2 years.
I have changed the brakes hoses, ball joints, and a few other bobs.
Advice I need is -
Front brake discs - I am having issues finding out what size the fronty discs are. Dingbro/Euro Parts has advised of 2 different sets - 256mm and 288mm. Any idea on rough prices?
Oil - Any recommendation on what oil and what number best to use. It is a 97 2.0 8v gti.
Spark plugs - Was going to just go for the bosch, however I ahve used NGK in the past. Any recomendations?
Any thing else I havnt covered - the car has been started in 2 years - I am going to change the oil. fuel , air and pollen filters too.
Any advice would be apprciated.
Thanks
Liam
Offline golf newbie
Re: Service Advice
« Reply #1 on: 03 May 2011, 10:59 »
sorry didnt read.
288mm front disks 256mm for the rear.
ngk spark plugs are ok i use them np.
15/40 semi oil
« Last Edit: 03 May 2011, 11:05 by golf newbie »
Offline WadGTI
  • Golf GTI'er
Re: Service Advice
« Reply #2 on: 03 May 2011, 11:11 »
Thanks
Eurocarparts are quoting £40+ for a brake disc? - is this correct? Can anyone double check.
Offline golf newbie
Re: Service Advice
« Reply #3 on: 03 May 2011, 11:20 »
Checked 43 quid each.
Try ringing your local motor factors..
Offline WadGTI
  • Golf GTI'er
Re: Service Advice
« Reply #4 on: 03 May 2011, 11:29 »
Thanks,
I will do,
Is it best to also renew the dizzy cap and rotar arm - or do you think I be ok with the existing. They look in ok nick.
Offline javalin
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline WadGTI
  • Golf GTI'er
Re: Service Advice
« Reply #6 on: 03 May 2011, 18:22 »
what I do...
http://javalins.wordpress.com/vw-golf-mk3/vw-service-parts-list/
Thanks for this buddy - very useful.
Any gains/pros to using the HT leads. The golf is standard and will be kept standard except from a cat back system and k/n airfilter.
Ordered the service stuff from euro parts with the discount code - got £25 discount :)
Offline javalin
Re: Service Advice
« Reply #7 on: 03 May 2011, 20:37 »
Hiya
Only that the cheap stuff is cheap for a reason.  I went through about 5 sets on the wife's Ford Fusion, before getting geninue Ford ones.  The cheap ones are rubbish and not worth it.
James
Re: Service Advice
« Reply #8 on: 03 May 2011, 21:36 »
Hiya
James
Gsf ones will be fine as they use the same suppliers as VW.  :smiley:
Offline Godzilla
  • <<<VR6 MADNESS>>>
Re: Service Advice
« Reply #9 on: 04 May 2011, 10:54 »
I have never used cheap leads before......What can cheap leads cause the car to run like....Could they alter performance and MPG?
Also WadGTI    If you are ever near Milton Keynes I have just under 5 litres of 10/40 semi/synth you can have as I have just got 5 litres of 5/40 fully synth so dont need the 10/40.....Will save you £20 odd quid  :smiley:
