Author Topic: Wayne's Skoda Octavia Vrs - Another induction kit pg92 - Update -page 98  (Read 293711 times)
Re: Wayne's Skoda Octavia Vrs - New wheels pg 59 & 63
« Reply #710 on: 01 November 2011, 13:37 »
Thats not bad.. although didn't you have some jip with brakes not that long ago?
I had trouble with a rear caliper, just hoping I don't need a front one now.  :sad:
Ah yes.. remember now... yeah lets hope not, when they said out of balance was it clear if it was binding or being slack?
Not sure, Dad is with the car but they said the fronts had a 35% difference  :undecided:
Offline SoundillusioN
« Reply #711 on: 01 November 2011, 14:50 »
Done anything with the fluid recently, air in the system maybe?
« Reply #712 on: 01 November 2011, 15:06 »
I have not unless it has air trapped from when the rear caliper was replaced  :undecided:
« Reply #713 on: 01 November 2011, 16:31 »
was the system fully bled when the caliper was changed?
« Reply #714 on: 01 November 2011, 16:38 »
Yes it should have been It was a local garage I know and trust, it is with a different garage for the mot.
« Reply #715 on: 02 November 2011, 12:05 »
What a nightmare  :angry:
I have news from the garage (Skoda main dealer), it looks like it needs a new front caliper, however they cannot supply a new caliper until the new year  :shocked:
So I have now managed to source one from VW from the morning, will need painting but that is no big deal.
Just hoping that it sorts the problem.
« Reply #716 on: 02 November 2011, 12:16 »
So you've been told you need a new one but have you been told why?  Dealers are always keen to replace rather than fix.
Offline Bellend
« Reply #717 on: 02 November 2011, 12:27 »
I'd try freeing it up and checking the discs and pads first.
Where all my moneys went.
« Reply #718 on: 02 November 2011, 12:37 »
Well the n/s front is reading 35% lower than the drivers side, discs and pads are fine (new less than 4k ago), they have also checked the discs with a dial gauge, all hoses are ok, sliders have been cleaned and lubricated, system has been bled twice yet it still has the fault.
So as a last resort they suspect the caliper is sticking / not working as it should  :undecided:
Offline Bellend
« Reply #719 on: 02 November 2011, 17:51 »
Ah fair enough. Sounds like a calliper next then. Add it to the price list.  :grin: :cry:
