Author Topic: rear driver side lights  (Read 1779 times)
Offline the_stink
  • A3 140 TDI
« on: 30 April 2011, 21:39 »
The rear light was out on the driver side, bought some new  bulbs and changed them and nothing?
tried the bulb on the passenger side and it worked fine  :undecided:
also replace the reverse lights and they don't work either, need to sort this before my MOT on 27th may
The brake lights work fine as do the indicators
« Last Edit: 30 April 2011, 21:48 by the_stink »
Offline cняis
Re: rear driver side lights
« Reply #1 on: 30 April 2011, 22:05 »
The non-funtioning reverse lights will probably be a reverse light switch fault, either the switch on the gearbox is dead or you have snapped wires going into the plug for the switch.
Reverse lights are not checked on the MOT so you can leave that for now.
IIRC the rear tail lights are on separate fuses? check those first :afro:
Offline the_stink
  • A3 140 TDI
« Reply #2 on: 30 April 2011, 22:26 »
yeah didnt think the reverse ones were a MOT prob , cool ill check the fuses and see if one has gone!  :smiley:
Offline the_stink
  • A3 140 TDI
« Reply #3 on: 01 May 2011, 19:35 »
checked fuses 7 + 8 and both look fine?  :undecided:
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #4 on: 01 May 2011, 19:43 »
Step away from the car Joe...  :evil: :evil:
Thom
Offline the_stink
  • A3 140 TDI
« Reply #5 on: 01 May 2011, 20:05 »
Thom
well i don't know what the hell is wrong  :embarassed: i was hoping with would be the fuse as ive got some spare ones from when i replaced the one for the stereo
Offline the_stink
  • A3 140 TDI
« Reply #6 on: 01 May 2011, 20:38 »
just went out and gave the contact a bit of a clean and after a fiddle its now working :rolleyes:
Offline cняis
« Reply #7 on: 01 May 2011, 20:46 »
It sounds like you're getting better at this maintenance lark!  :grin:
Offline Sam
  • Sam I am
« Reply #8 on: 02 May 2011, 11:42 »
He will soon be at the status of rubjonny
