Author Topic: Rear disc question  (Read 2879 times)
Offline cняis
Re: Rear disc question
« Reply #10 on: 01 May 2011, 11:46 »
Not too much grease mind, in fact bearings normaly come with a small sachet which is more than enough.  :smiley:
This ^
OK thought I needed loads, the old ones are swimming in it!
A little goes a long way  :laugh:
Its quite nice having it all over your hands but for gods sake wear latex gloves!
Offline emery1990
« Reply #11 on: 01 May 2011, 16:27 »
Yer these didn't come with nothing  :rolleyes:I ordered a big tub of it off ebay anyway, just use the old lube, looked pretty fresh anyway for the disc I have got, managed to hit them in with a hammer and inch pole.
All done, but the pads are rubbing on my discs, do I need to push back the piston as far back as it will go?
« Last Edit: 01 May 2011, 17:56 by emery1990 »
VW BUSH
« Reply #12 on: 01 May 2011, 19:16 »
you will need to push the pistons all the way back when fitting new pads to new discs.
Make sure you take the cap off the fluid res on the Master cylinder when pushing back the pistons.
Blead the calipers as well, the rear brakes can get a bit sticky on Mk2/3 golfs.
 :smiley:
Offline emery1990
« Reply #13 on: 01 May 2011, 19:26 »
Cheers mate, I did try pushing them back without cap on, obviously they didnt move though! Ahh more break bleeding lol
Offline cняis
« Reply #14 on: 01 May 2011, 23:22 »
they need pushing and turning on mk2s and mk3s
a g-clamp will suffice or a big pair of grips. a bit pikey but will do the job!
