Author Topic: exhaust manifold studs snapped :@  (Read 3994 times)
Offline spudboy6
  • Just like a golf ......
Re: exhaust manifold studs snapped :@
« Reply #10 on: 25 April 2011, 19:15 »
Cheers guys for the help ' anyone know where I can buy them from now ?
Offline dom
  • Back in a Mk4
« Reply #11 on: 25 April 2011, 19:18 »
VW :wink:
Offline stupow
« Reply #12 on: 25 April 2011, 19:39 »
You can buy a broken bolt extractor kit. Wich has screw like bits that have revers threads on them.
You drill a hole in middle of stud then screw extractor onto it then just under it and take it out.
this is your best bet, just google easy outs
« Reply #13 on: 25 April 2011, 20:44 »
If a stud extractor will not get it out then you may need to remove the head to drill it out as you will not have enough room.
Offline spudboy6
« Reply #14 on: 25 April 2011, 21:02 »
I think I would just weld the manifold on instead ha
Offline stainesy
« Reply #15 on: 25 April 2011, 21:11 »
yeah thats what there called easy outs.
they work i bought some as had same problem on my old car and they work a treat  :wink:
Offline spudboy6
« Reply #16 on: 26 April 2011, 18:05 »
got the nuts and studs today from a place called slough TPS , i think they only supply the motor trade ,
studs 68P each
nuts 35P each ,
going to weld nuts on to them and get them out later tonight ,
thanks for all the help !
Offline Bellend
« Reply #17 on: 26 April 2011, 20:50 »
My nans Polo has snapped studs. We're gonna take the front panel out and drill em.
Where all my moneys went.
Offline spudboy6
« Reply #18 on: 26 April 2011, 23:23 »
I got the one stickint out the block out by welding a nut on ! All I have to do Tommrow is tackle the flush one :/ ha
