Author Topic: Adding electric mirrors?  (Read 2678 times)
Offline Mr Blue
Re: Adding electric mirrors?
« Reply #10 on: 12 September 2007, 01:17 »
green wire is connected to the rear window demister switch (not needed)
yellow is positive (+) ignition live
brown (-) is earth
Its been 3 years since ive fitted mine so if it catches fire. dont blame me :grin:
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #11 on: 12 September 2007, 10:26 »
ive got a complete non cut set ill try and help from when i can reach me lockup  :smiley:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline pork_pie
« Reply #12 on: 12 September 2007, 13:33 »
HAHAHA, catches fire!  i hope not...
thanks for the info guys
mattneck:  your a gent, a pick would be ace..
Mk2 16v is off the road :(  Mk3 8v has taken its place :)
« Reply #13 on: 19 November 2007, 09:48 »
still require a pic pork pie? im fitting mine today i think  :smiley:
Quote
Offline dabill
« Reply #14 on: 19 November 2007, 10:26 »
i'd love some pics too if you would be so kind, think its this weekends job for me! unless it snows again!
noble tuned - and still not fast enough!
« Reply #15 on: 19 November 2007, 11:14 »
best i can do.. best idea ive got anyway is tae a picture of the plugs on each end.. makes it obvious which wire leads where at least, think john may have a diagram to which could help!  :smiley:
Quote
« Reply #16 on: 19 November 2007, 11:19 »
CE2:
D/11 - electric mirrors ign live feed
K/12 - heated mirror glass
CE1:
E/15 - heated mirror glass
G/1 - electric mirrors ign live feed
Offline dabill
« Reply #17 on: 19 November 2007, 14:27 »
should i splice the live into anoter live, or is there somewhere that i can connect it to withough soldering/cutting anything? want it as neat as possible...
diagram is a major help too rub! thanks!
« Reply #18 on: 28 November 2007, 12:52 »
if its a 90 spec you might have a spare black wire from the D plug hanging about round the back of the fb, if not you'll need to chop a plug out of another 90 spec VW and pop it into the missing D plug pin on your fusebox.  Check my fusebox FAQ for more information :)
