Author Topic: Couple of issues  (Read 2017 times)
Offline apie2004
Couple of issues
« on: 20 April 2011, 09:15 »
1) Had a bit of a shock last night when I overtook a car, put my lights on main beam and then when I dipped them next.....nothing. I have an uprated loom on but this morning I tested the lights and they are working. What would cause an intermittent problem like this?
2) Also parked my car on a hill last night and when I came to start it (last night) it spluttered into life from cold and struggled to maintain an idle and would stop without a bit of throttle, same happened again this morning but the car was on the flat. Once the car has warmed up it holds an idle, It hasnt done this until now, car is a digi 8v.
James
Offline apie2004
Re: Couple of issues
« Reply #1 on: 25 April 2011, 20:02 »
Bump
« Reply #2 on: 25 April 2011, 20:02 »
Headlights could be a faulty switch
Offline dadrathers
« Reply #3 on: 25 April 2011, 20:10 »
Unable to help with '1' - sorry.
For '2' - have you replaced the blue temperature sensor lately/ever? - First thing to try. Search for more info. on blue temp sensor.
Cheers.
Offline apie2004
« Reply #4 on: 25 April 2011, 20:12 »
Closer to never, car didnt come with any S/H. Time for a change methinks, cheers
Offline apie2004
« Reply #5 on: 26 May 2011, 21:53 »
I have changed the headlight switch and the lights still dont work, I have sidelights but no dipped, main beam works. What could this be?
Offline raferackstraw
« Reply #6 on: 26 May 2011, 21:59 »
look for loose or broken wires on the uprated loom, depending on the quality of loom the connectors could be fubar, look particularly at the wires that connect to the stalk control high/low beam in the engine bay
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
