Author Topic: hub bolt stuck on mk3 golf  (Read 3584 times)
Offline gino-93
« on: 17 April 2011, 16:14 »
hi
im trying to change the drive shaft on my mk3 golf (passengerside) and the bolt and treads are completely f*cked, its not going anywhere, i tried using some scaffolding bar and all it did was bend the the metal i put it on!!!.
what can i do will i have to cold chisel it off?
1.9tdi PD100 ATD engine bits for sale!!!
pm me for parts
Offline JC
  • Back in the North.
Re: hub bolt stuck on mk3 golf
« Reply #1 on: 17 April 2011, 16:21 »
erm, pictures required , cos how the hell has the thread been damaged, the nut usually only just covers the end of the threads  :huh:
Offline gino-93
« Reply #2 on: 17 April 2011, 16:25 »
will get pics tommorow, as im at work in an hour, there is like 4 threads showing, and the person before must have given up and just battered it to try get it off but was unsuccessful
pm me for parts
« Reply #3 on: 17 April 2011, 16:31 »
Very strange.  :undecided:
Unless it was cross threaded.
Offline AudiA8Quattro
« Reply #4 on: 17 April 2011, 16:51 »
3/4 inch drive breaker bar will do it.
Offline gino-93
« Reply #5 on: 17 April 2011, 17:23 »
looks like they have been chisiling away at it and all the threads are destroyed as in flat?  :undecided:
i really need it off as my driveshaft is gone
cheers
pm me for parts
Offline Bellend
« Reply #6 on: 17 April 2011, 18:08 »
Doubt it's that, they are fecking tight. I literally lifted the car off the axle stand undoing it.
Needs to be a 90 degree, not at all bent, bar and it will slowly loosen.
If it's THAT bad just angle grind the showing threads.
Where all my moneys went.
« Reply #7 on: 17 April 2011, 18:58 »
You tried to undo the nut when the car was on stands?
You're a braver man than me  :grin:
Offline JC
« Reply #8 on: 17 April 2011, 19:17 »
or just living up to his name  :grin:
« Reply #9 on: 17 April 2011, 20:23 »
 :lipsrsealed:  :smiley:
