Author Topic: how too (bodge) fit a mk4 steering wheel  (Read 16849 times)
Offline boneybradley
  • Back in a Mk3...
Re: how too (bodge) fit a mk4 steering wheel
« Reply #10 on: 14 April 2011, 10:02 »
So are you saying an airbag light will be an mot failure in the future?
yep as far as I know all non working warning lights will be a mot failure soon.....
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #11 on: 14 April 2011, 10:18 »
So would this mean that for all those that have fitte aftermarket non-airbag steering wheels they'd also need to retro fit a non-airbag / ABS warning light panel on the dash from a lower model?
  • Back in a Mk3...
« Reply #12 on: 14 April 2011, 10:21 »
or fit a resistor (which should be supplied with the boss kit..I know momo include them)
« Reply #13 on: 14 April 2011, 10:26 »
But that would still leave an airbag light on the dash, does the resistor stop it lighting or just let the airbag ecu do it's initial checks then switch off the light as if there was an airbag still fitted?
  • Back in a Mk3...
« Reply #14 on: 14 April 2011, 10:32 »
a resistor lights the bulb and then turns it off like normal
« Reply #15 on: 14 April 2011, 10:37 »
Ok. Personally i wouldn't want a pointless light flashing on and off every time i started my car and would change the warning light panel but I guess most people wouldn't worry about it as long as it passed the MOT. Im just fussy like that though.  :smiley:
Offline Dan_GTi8v
« Reply #16 on: 14 April 2011, 10:43 »
my airbag lights been on for about a year now, no idea why it just randomly came on one day and I never got round to finding out why :P Guess I better investigate
Offline dan_apps
  • too low for british roads!
« Reply #17 on: 14 April 2011, 18:13 »
if thats the case surely you could simply take the bulb out the clocks for the airbg warning light and mr mot tester would never know!
VW BUSH
« Reply #18 on: 14 April 2011, 19:24 »
as well as a whole bunch of stuff which will affect modded cars......................
Offline murraymint
« Reply #19 on: 14 April 2011, 21:25 »
Sticky?
If the aribag works and it gives no faults I will sticky this
yh the air bag just plugs straight into the connector on the car
this red connetor is the airbag connector and just gose straight thru the mk4 wheel and into the airbag. the mk3 and mk4 airbag connectors are the same
after i pluged the mk4 airbag in, i turned the engine on and the airbag light came on and then went off as normal
« Last Edit: 14 April 2011, 21:46 by murraymint »
josh
