Author Topic: Puzzled  (Read 8473 times)
Offline Len
Puzzled
« on: 12 April 2011, 13:38 »
I have a Sony 4 channel amp that works the front door speakers and 2 channels bridged to a sub.
Was checking my sysytem and the front speakers were working fine but the sub wasnt!
So I checked the speaker cable to the sub and was fine. Checked the earth and all the terminals on the amp and all seemed fine.
So in a bit of a tizz I slammed the hatch down hard, the sub sprang into life!
So my question is should I be looking for a new amp?
www.sas.org.uk
www.the-ace.org.uk
Offline B-chi
Re: Puzzled
« Reply #1 on: 12 April 2011, 16:03 »
Try switching it around. See what happens.
Offline Len
Re: Puzzled
« Reply #2 on: 12 April 2011, 16:39 »
What? The outputs from the amp? Swap the fronts with the sub? That what you mean?
www.sas.org.uk
www.the-ace.org.uk
Offline B-chi
Re: Puzzled
« Reply #3 on: 12 April 2011, 17:06 »
Yeah 4ch amp. Ch 1 front left, ch 2 front right, 3&4 sub.
Try 1&2 sub and 3&4 front left and right.
Does it have adjustable x over on all channels? You'd need to lpf 1&2 for the sub and hpf for 3&4 on the fronts.
Offline Len
Re: Puzzled
« Reply #4 on: 13 April 2011, 21:56 »
The fronts are bass speakers, that make any difference?
www.sas.org.uk
www.the-ace.org.uk
Offline B-chi
Re: Puzzled
« Reply #5 on: 13 April 2011, 22:50 »
I'm lost now sorry mate.
What do you mean by bass speakers?
I thought you said it was front door speakers.
Offline Len
Re: Puzzled
« Reply #6 on: 14 April 2011, 08:57 »
I have coax mid/tweets in the dash run off the HU and the front door speakers are mid/BASS run off the amp.
They are SPL Dynamics HF-6.1
Second edit:- 45 - 5000 HZ is the frequency response of those door speakers.
« Last Edit: 14 April 2011, 09:02 by Len »
www.sas.org.uk
www.the-ace.org.uk
Offline B-chi
Re: Puzzled
« Reply #7 on: 14 April 2011, 09:29 »
Ok so your kind of running active.
That's fine. On the 4ch do you have the same controls (filters) on ch1&2 as on ch3&4. If so when you change them over to test ch3&4 just mirror them. Ie make 3&4 the same as 1&3 were and vise versa. Were just trying to establish if the problem happens on all 4 ch or just 2.
Offline Len
Re: Puzzled
« Reply #8 on: 14 April 2011, 12:44 »
Active?
Not sure!
Think it only has one "volume" control on the amp. Not sure about filters? :undecided:
www.sas.org.uk
www.the-ace.org.uk
Offline B-chi
Re: Puzzled
« Reply #9 on: 17 April 2011, 01:21 »
All they do is stop nasty freqs speakers don't like destroying them.
You don't want to play a 30Hz tone through a tweeter. It's not going to last very long.
Any luck finding out the problem?
