Author Topic: Spark plugs really tight! :(  (Read 3407 times)
Offline mark-mk3gti
« on: 08 April 2011, 17:25 »
Noticed today my in 02 light flashing, so thought I'd have a look round at changing the plugs first.
Only got 1 out of the 4 to come out fairly straight forward, one starts to turn then it stops, 1 barely turns and the last turns a bit and stops as well..
The one that did come out didn't look bad, so don't think it's essential to change, but may improve fuel consumption a bit if I cud change em
Tried spraying wd40 at em and leaving a bit, then tried with engine warm at 50 then nipped to shops and got to 76 but Only slight improvement,
Have called it a day cos don't wanna break em cos it's my daily, but unsure as what to do.. Should I take to a garage and pay to get em changed then at least if they balls it up there is some sort of comeback to them..
Any thoughts?
Re: Spark plugs really tight! :(
« Reply #1 on: 08 April 2011, 17:47 »
I would let a garage have a go tbh :smiley:
Offline mark-mk3gti
« Reply #2 on: 08 April 2011, 18:54 »
Yeah that's what I was thinking, just thought there maybe some old wives tale that would make them fly out, lol,
It is evident that there is no anti seize on the plugs, don't understand why u wouldn't put it on, really silly in my opinion, know people wud argue not to put it on, but old cars and all,
Anyway off to the garage at some point it will be...
Cheers Wayne...
Btw did u ever get that golf a while back? Mk3 wasn't it?
Offline Khare
  • The bear that khares
« Reply #3 on: 08 April 2011, 18:58 »
I'd spray a shot of plusgas around the plugs and use careful steady force to undo them. Use a breaker bar or something to make leverage. Do it with a stone cold engine too to avoid stripping the threads.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 08 April 2011, 19:17 »
As above, Id loosen them as much as you feel comfortable with then spray some Plusgas into the recesses then leave over night if possible then get a decent bar or ratchet on them the following day. Even if the one you did get out looked fine they've still got to come out at some point so why leave them longer?
Offline Bellend
« Reply #5 on: 08 April 2011, 20:08 »
No, no, no, no, no.
Sorry.
DO NOT USE A BREAKER BAR IF THEY ARE THAT TIGHT. They sheer and you will be taking off the head.
Use a solid bar, not too big, and go back and forward in small amounts. Firm but not too firm. Hard to explain.
I'd let a garage do it if you aren't confident.
Where all my moneys went.
« Reply #6 on: 08 April 2011, 22:28 »
I had a mk3 a while ago, looking at mk4 1.8t or Leon 1.8t's at the moment.
Offline Khare
« Reply #7 on: 08 April 2011, 22:32 »
No, no, no, no, no.
Sorry.
I say a breaker bar so you can put some more force into it. I remember trying to undo the plug son the 8v for the first time since owning it and the standard spark plug tool wouldn't cut it, just hurt my hands. Got a deep socket, a small breaker bar and voila.
Offline snifferdog
« Reply #8 on: 09 April 2011, 08:22 »
I had the exact opposite problem last week, one of my plugs had come loose and was wobbling about  :undecided: :grin: Seems alright now Ive given it a tightening though  :laugh:
Offline robz
« Reply #9 on: 09 June 2011, 08:06 »
candle wax :D :D
couldnt resist mate :D
