Author Topic: Spark plugs really tight! :(  (Read 3399 times)
Offline mark-mk3gti
Re: Spark plugs really tight! :(
« Reply #20 on: 09 June 2011, 14:52 »
I wouldnt want drill swarf getting in my engine!
neither would I!! but apparently this guy does it in a special way as to avoid it somehow, hence why its 50quid a hole, thou i am not sure what he could do!
the other option would be to get a replacement head i guess, but its all gonna cost, and that tes down south sells refurbed/rebuilt 8v engines for 695, or pick one up cheap somewhere from breakers..
who knows..
Cant see how!
The ONLY way is to drill them out and retap.
neither can i to be honest, and im not that mechanically minded, it is a bit of a tw@t really, and the guy i bought it off was a honda technician, and has spent a fortune on it over his time owning it, but somehow neglected to spark plugs, it wasnt something i thought to check when i bought it, cos i needed a car asap, and this seemed a good buy..
ill get it sorted at somepoint.. :) however any other old tricks, are welcomed..:)  i was told to run reddex through it, cos can help clear the build up on the plugs, but like i said to robz last night, i have heard mixed opinions on that treatment...
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #21 on: 09 June 2011, 15:11 »
I can't see how Redex or any other fluid is going to penetrate the deeply seated and corroded threads of a spark plug.
Offline Len
« Reply #22 on: 09 June 2011, 16:00 »
What you need is the USA version of WD40.
Trouble is you can only get it from 2 sources in this country!
Its great stuff, can really recommend it.
It is a proper ingress fluid that trully does impregnate threaded joints.
Cant remeber the name off hand but will post tomorrow with details.
WD40 is after all only a water displacement.
www.sas.org.uk
www.the-ace.org.uk
Offline mark-mk3gti
« Reply #23 on: 09 June 2011, 16:31 »
Hi Len, that info would be very useful! Cheers..
Offline MotorPsycho
  • I drive a 2000bhp dragster, so what ;)
« Reply #24 on: 10 June 2011, 08:43 »
if it's the same thing I'm thinking of its now available in Europe, Gibbs Brand - AMAZING stuff :)
http://www.gibbsbrandeurope.com/home.html
1983 mk1, 2.0, TSR pack C head, Eaton M45 - work in progress
1990 mk2 GTD, boost, fuel, soot
16v GTi mk3; chilli red, 16" Audi Speedlines, coilies
1934 Ford Dragster, 200mph in 6 seconds.
Offline robz
« Reply #25 on: 10 June 2011, 08:54 »
worth a try that mark??
know the felling when its your daily. the urge to sort thing is burning away but you darent in case you make it worse!
i gave in to the temptation a few times and the worst happened, shell still hasnt forgiven me :D
Offline Len
« Reply #26 on: 10 June 2011, 09:14 »
Yep that's it! Gibbs Brand! Cheers Psycho! :wink:
I did go down the garage last night and look! :grin:
YES it is worth a try! If that stuff dont loosen those plugs nothing will.
But OP dont expect instant results! When you get it give it a really, really long spray into each hole, Oh take leads off first! :grin:
Then warm the engine (having reconnected leads), switch off and leave for about half an hour to let it soak in, then try to undo, but use a normal tool DO NOT use a socket and breakerbar!!
« Last Edit: 10 June 2011, 09:20 by Len »
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #27 on: 10 June 2011, 13:53 »
Shame you aint going to RR day at Rtech, could have brought the stuff with me.
www.sas.org.uk
www.the-ace.org.uk
Offline mark-mk3gti
« Reply #28 on: 10 June 2011, 18:23 »
hey ho,
thanks for the link, when payday comes next week ill get one ordered, 15quid it could be a bargain if it loosens these pesky plugs... will update when ive give it a go...  :)
cheers all
