Author Topic: New power for my headunit??  (Read 3913 times)
Offline mk3valver
« on: 07 April 2011, 13:13 »
Somehow whilst trying to fit an aerial amplifier I have lost the power to my headunit?! Firstly I noticed it had gone with the ignition on but when I turned it off the stereo came on? My mechanic has told me to take power from somewhere else. Has anyone got any ideas as to where from though or any other fixes?
 Thanks in advance, Matt
Offline Len
Re: New power for my headunit??
« Reply #1 on: 07 April 2011, 13:32 »
Had a similar problem with mine a long time back!
Think all we did was swap the live and remote wires. Just means HU is permanently live.
www.sas.org.uk
www.the-ace.org.uk
Offline mk3valver
« Reply #2 on: 07 April 2011, 13:44 »
Right I'll go and have a pop now, thanks
Offline mk3valver
« Reply #3 on: 07 April 2011, 14:13 »
It's not even coming on when the ignitions off now, it does make a noise like the cd's ejecting but no lights or owt?
Offline trog_nfs
« Reply #4 on: 07 April 2011, 14:35 »
sounds like you ignition live might be knackered. Get a multimeter on the ignition feed and if its 0 V, theres your answer.
Temp measure would be wire it up permanently - attach red and yellow wires to permanent live.
Proper fix would be new ignition switch
Offline mk3valver
« Reply #5 on: 07 April 2011, 15:36 »
No thats not working either, any other ideas?
Offline Len
« Reply #6 on: 07 April 2011, 16:54 »
Might have to take a new wire direct from the battery then or from the fuse box.
www.sas.org.uk
www.the-ace.org.uk
Offline trog_nfs
« Reply #7 on: 07 April 2011, 17:09 »
You haven't blown a fuse or something silly like that have you?  :laugh:
Offline mk3valver
« Reply #8 on: 07 April 2011, 17:25 »
No, checked the fuses first thing. I put a another stereo on without the adaptor for the stereo that I use normally and swapped the wires like you said, that gave me power with my ignition off. But it goes off when I turn it on and /or remove the key. So when I managed to do this I put the adaptor back on with my normal stereo and nothing!!! Not even when the ignition is off! Can I just steal power from something else at the fuse box? And if so what do you recons best and how's best to do it. Again thanks for your help :)
Offline mk3valver
« Reply #9 on: 07 April 2011, 17:52 »
Apparently I can run from my cigarette lighter as it on the ignition too, does anyone know what colour live is?
