Author Topic: Help with my zero knowledge on car audio  (Read 7503 times)
Offline AJ_EQ
« on: 07 April 2011, 12:56 »
Just bought my mk4 and so far I love it.  The only problem is the parcel shelf has two massive gaping holes in it....
In the future Id like to put a stealth shelf in and keep the oem look.
For now though I have just bought a couple of JBL 6 x 9 to fill the holes.  I would like to link them up to the oem headunit, but I have no clue how to do this.  I already have rear passenger speakers and didnt know how this would affect the setup.
Any help would much appreciated.
Offline Len
Re: Help with my zero knowledge on car audio
« Reply #1 on: 07 April 2011, 13:33 »
You will need an amp to power the 6x9's in the shelf.
www.sas.org.uk
www.the-ace.org.uk
Offline Horney
« Reply #2 on: 07 April 2011, 13:37 »
And if you still have the standard VW head unit that's going to be difficult. Ideally you need to pick up a new headunit that has a pre-out to run an amp. Either that or buy a parcel shelf without holes in and sell the speakers you just bought.
nick
Offline AJ_EQ
« Reply #3 on: 07 April 2011, 14:12 »
hmmm.  My girlfriend runs 6 x 9's (came with her car) just with a jvc headunit.
Ideally I'd like to keep the oem look in the front, but if its not possible to run the 6 x 9's off it, I have a kenwood unit in my corrado I could steal.
Offline AJ_EQ
« Reply #4 on: 07 April 2011, 15:10 »
Also she has clips between the 6 x 9 wiring and the wiring to the HU.  Any idea where I could get these?
Just means I can whip out the parcel shelf when I need to put my Mtb in the back.
Offline B-chi
« Reply #5 on: 08 April 2011, 15:22 »
You don't need an amp just disconnect the rear speakers and use the cabling for them.
Offline AJ_EQ
« Reply #6 on: 08 April 2011, 17:19 »
thank you, exactly what I need.  Is it missions to get the wiring out of the rear speakers?  Will standard HU beable to power 6 x 9's?
Offline B-chi
« Reply #7 on: 08 April 2011, 17:56 »
Yes mate to both.
Offline Tazzy
« Reply #8 on: 09 April 2011, 12:02 »
what power are the 6x9s? standard manufacturer cabling is a bit sh!te imo, but will do the job fine, as mentioned, an amp will do a much better job and make the 6x9s more clearer, just to add, parcel shelves are flimsy and may break from the weight on them
If It Comes Off, Modify It!
Offline B-chi
« Reply #9 on: 09 April 2011, 12:32 »
It doesn't matter what power the speakers are. It's the amp that defines the current load on the cable.
The HU will put out the same watts whether a 10w or 1000w speaker are attached.
Output of hu will be between 10-30w rms.
