Author Topic: Hesitation around 3000rpm  (Read 2353 times)
Offline ebo007
« on: 05 April 2011, 19:31 »
Hi,
My car is hesiatating around 3000 rpm in every gear other than 1st. Between 3 @ 4k it seems down on power/torque. The car has recently had full service with all filters, plugs, belts, dizzy cap and rotor arm changed but it is still happening.
My mechanic noticed the rearbox baffles on the exhaust had gone, could this be causing the problem? There was also some black string out of my exhaust a few weeks ago, i'm guessing this was from the cat if thats gone could this be the problem?
Any suggestions appreciated? Had a search but couldn't find what I was looking for.
Offline Seanl
Re: Hesitation around 3000rpm
« Reply #1 on: 05 April 2011, 20:09 »
If its misfiring, or has previously at those revs, it would probably indicate a duff MAF (did on mine anyway). All I did to sort it though was give it a quick squirt with the contact cleaner which sorted it, but I still get a slight hesitation at that point. I have replaced the MAF with a used one to see what happened but its exactly the same mate. Dont know if its a common thing on them, or the misfire was masking a slight problem somewhere else. I dont rag the sh!t out of it, and dont often go that high up the rev range so it doesnt really bother me.  :smiley:
Offline maxmc2
« Reply #2 on: 06 April 2011, 10:20 »
I had exactly the same problem on mine, my car now runs like a dream WITHOUT the MAF :)
Offline stainesy
« Reply #3 on: 06 April 2011, 13:59 »
Without the MAF. Does it work ok like that? Won't that cause problems or damage anything?
Offline Luke1981
« Reply #4 on: 06 April 2011, 17:28 »
I wouldn't advise removing the MAF. Its there for a reason mate. Get it checked out sooner rather than later  :wink:
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline ebo007
« Reply #5 on: 06 April 2011, 17:36 »
No misfire, its running sweet just down on power between 3&4000 rpm.
Offline ebo007
« Reply #6 on: 12 April 2011, 12:33 »
anyone?
Offline Len
« Reply #7 on: 12 April 2011, 13:11 »
ECU relay
www.sas.org.uk
www.the-ace.org.uk
Offline ebo007
« Reply #8 on: 04 May 2011, 19:05 »
where can I find the ECU relay and why would this cause hesitation?
Offline golf newbie
« Reply #9 on: 04 May 2011, 19:21 »
ecu relay is number 30
in the fusebox just above the brake pedal..
