Author Topic: Hesitation around 3000rpm  (Read 2359 times)
Offline harlemex
Re: Hesitation around 3000rpm
« Reply #10 on: 05 May 2011, 13:13 »
200 says its not the ecu relay  :grin: :grin:
Offline WadGTI
  • Golf GTI'er
« Reply #11 on: 06 May 2011, 00:50 »
I had the exact same problem on my old 200sx. Never got it solved, however sources did tell me the ECU have been a culprit.
Offline stainesy
« Reply #12 on: 06 May 2011, 12:16 »
I have just fitted and after market backbox to my gti 8v and I sudenly now have the same hesitation between 3000 and 4000 revs.
Offline golf newbie
« Reply #13 on: 06 May 2011, 12:18 »
Is the back box brand new..?
Could be partially blocked if second hand..
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
« Reply #14 on: 07 May 2011, 01:36 »
Mine didnt really hesitate just felt like it had more to give but since my de-cat feels far better and revs alot more now could even be the CAT.
Golf Gti
Offline gti gaz
« Reply #15 on: 07 May 2011, 10:57 »
have seen lots of people saying about this usally air flow meter or ecu relay if you have tried these try crank breather pipe give it a good clean with some form of cleaner then try throttle body clean with carb cleaner if still no joy, change back box maybe cat depends how much gash you have hope this helps
 Any one in cornwall lets sort more meets!!!!
Offline liva2704
« Reply #16 on: 15 May 2011, 20:22 »
I had the same problem and noticed that there was a ticking noise coming from the throttle body and it turned out to be the throttle position sensor sticking,slackened throttle cable bit of wd40 a few taps and now it flies.
