Author Topic: boost gauge does anybody no what vaccum pipe  (Read 4003 times)
Offline golf1.8t
« on: 18 March 2005, 11:17 »
just got my boost gauge and not sure how to fit it any help would be great and save me some money getting it fitted for my next mod thanks
« Last Edit: 18 March 2005, 15:53 by golf1.8t »
DUBBIN FOR LIFE:
Offline dubvrs
Re: boost gauge does anybody no what vaccum pipe
« Reply #1 on: 18 March 2005, 17:31 »
Use the one that goes to the top of the dump valve.
Pic of mine.
Offline golf1.8t
« Reply #2 on: 20 March 2005, 21:05 »
how did you get that nylon tube through to the inside of the car from the engine and what valve have you got there recirc/atmos
DUBBIN FOR LIFE:
Offline golf1.8t
« Reply #3 on: 24 March 2005, 18:52 »
i tryed that pipe but it seems to be a bit jumpy wen i rev the engine
DUBBIN FOR LIFE:
Offline A1Crazy
« Reply #4 on: 26 March 2005, 15:35 »
don't use that hose.  Use the one off of your fuel pressure regulator.  It is a direct feed off of the manifold.  The hose going to the diverter valve has pressure regulated by a couple valves and is not accurate
Emile<br /><br />02 Golf GTI<br />91 Cabriolet Etienne Aigner<br />82 Rabbit LS
Offline golf1.8t
« Reply #5 on: 26 March 2005, 23:16 »
weres that and what does it look like.
DUBBIN FOR LIFE:
Offline golf1.8t
« Reply #6 on: 30 March 2005, 19:29 »
any body out there.
DUBBIN FOR LIFE:
Offline A1Crazy
« Reply #7 on: 02 April 2005, 18:44 »
Offline golf1.8t
« Reply #8 on: 02 April 2005, 22:49 »
cool thanks ill try that could you also tell me an simple route to get the little nylon pipe into the car.
DUBBIN FOR LIFE:
Offline A1Crazy
« Reply #9 on: 02 April 2005, 23:59 »
I used zip ties to run it next to the hard plastic brake vac line.  Then I ran it in the firewall thru the grommet located next to the brake booster
