Golf mk2
Starter motor
Topic: Starter motor (Read 1307 times)
Lewi 8v
Starter motor
31 March 2011, 19:40 »
Does anybody know if i can put a Starter Motor from a post 90 spec 8v on a pre 90 spec 8v? mines is a 86 model. Cheers
Wayne
Sir Postalot
Re: Starter motor
31 March 2011, 21:33 »
Yes should be fine, 8v is different to 16v I believe however.
Lewi 8v
Re: Starter motor
01 April 2011, 17:31 »
Cheers Man.
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: Starter motor
04 April 2011, 11:30 »
86 is a k-jet most likely, and if so you must use a k-jet starter to replace it otherwise the 5th injector wont work. mk2 8v k-jet or 16v will be fine, the way to tell is to check the spade terminal connections on the starter, k-jet ones have 2
Lewi 8v
Re: Starter motor
04 April 2011, 13:21 »
Cheers for that.
Golf mk2
Starter motor
