Author Topic: ARP Rod bolts  (Read 2540 times)
Offline aaron1980
ARP Rod bolts
« on: 26 March 2011, 14:51 »
Hi does anyone know where i can buy a set of Arp con rods for a 16v kr i have searched but have had no luck. any pointers would be good thanks :smiley:
Offline DOA
Re: ARP Rod bolts
« Reply #1 on: 26 March 2011, 15:08 »
http://www.arp-bolts.com/pages/dealers.shtml
Are you sitting down?
http://www.coordsport.com/attachments/arp/ARP_Price_List_January_2010_-_VW_&_Audi.pdf
Out of interest, why are you looking at uprated bolts? Do you run a very high rev limit or stock?
« Last Edit: 26 March 2011, 15:13 by DOA »
Offline tech1889
  • Mk2 GTI FTW !!
Re: ARP Rod bolts
« Reply #2 on: 26 March 2011, 15:29 »
bargain they are lol
Offline aaron1980
Re: ARP Rod bolts
« Reply #3 on: 26 March 2011, 15:33 »
Hi thanks for that i have had a look but i cant seem to work out which ones i need? i knew they would be £100 or so
The reason i wanted to use arp bolts is when i have checked my engine to put it back togeather one of my bolts is streched to the point where it is thin in the middle :undecided: so i think its better to change the lot and vw want all but £7 each plus vat for standard ones so i may as well buy the arp ones for peace of mind. one other question is i know the standard bolts need to be pressed in which means i will have to remove the rods do you know if its the same useing the arp ones? thanks again for the help
Offline DOA
Re: ARP Rod bolts
« Reply #4 on: 26 March 2011, 16:49 »
Fair do's  :smiley:. Get on the phone and ask of you dont know wat you need lol. Makes me wonder what we did before the internet  :laugh:.
Yep, same for the ARP ones, should be a case of press the old ones out and press the new ones in as far as I know. At least getting the new ones in wont be as hard as getting the old ones out as you can tighten the nuts up to get the new ones in (use an ali spacer if the bolts wont fit all the way through the cap). I think I would be pressing them out with the cap installed too btw, at least to get them moving.
Offline tech1889
  • Mk2 GTI FTW !!
Re: ARP Rod bolts
« Reply #5 on: 26 March 2011, 16:52 »
internets always been here no ?
Offline DOA
Re: ARP Rod bolts
« Reply #6 on: 26 March 2011, 16:55 »
I distinctly remember having to buy wank mags when I was younger  :evil: :laugh:.
Offline tech1889
  • Mk2 GTI FTW !!
Re: ARP Rod bolts
« Reply #7 on: 26 March 2011, 16:57 »
 :grin: :grin: :grin:
Re: ARP Rod bolts
« Reply #8 on: 26 March 2011, 23:24 »
Standard bolts will be fine, from memory they are not pressed in, can be replaced with a small hammer.
Offline aaron1980
Re: ARP Rod bolts
« Reply #9 on: 27 March 2011, 09:15 »
[/quote]
ok thanks for that. :smiley: do you know if the ones from gsf would be any good?
