Author Topic: xenon high beam problem  (Read 10372 times)
Offline OKENEMEM
« on: 25 March 2011, 10:53 »
ive recently bought a golfmk6 tsi
its had a golf r replica kit put on .
which included the oem xenons and dlrs
when i switch car on i get light errors , rear/front  foglights and main beam not workin although they do
the only thing that doesnt work is the high beam on my lights
it seems like a electrical prob or mayb they have hooked up lights wrong.
can anyone shed light on this issue
Offline DRC
Re: xenon high beam problem
« Reply #1 on: 25 March 2011, 11:16 »
Was it the one on eBay by any chance? Black one?
Wait for the Doc the reply, he's wired his own lights up and there are modifications required to the headlights to get full beam working.
Your other bulb warnings will be due to the LED rear lights they've put on, you'll need someone with vcds to code them for you :)
Welcome to the forum!
'13 Audi A3 8V S-Line - Dakota Grey - 2.0TDI 150 - MMI Plus Nav - Bang&Olufsen - Comfort Pack - LED Lighting Pack - Comms Pack - Model and Technology Badge Deletion
Offline SteveP
« Reply #2 on: 25 March 2011, 12:17 »
It will be the BCM, you need one ending in part number 087 D or E for it to be able to support the Xenon shutters. The other versions do not have the pins connected in connector C for this.
Offline Keithuk
« Reply #3 on: 25 March 2011, 12:21 »
Or have a word with SteveP XENONS - Questions and answers on retrofitting and functionality.
With the parts I have left from the conversation I was working on for my Tiguan and as part of putting mine back to standard ready for chopping it in a month or so I am going to have a large number of the parts available for this conversion, I would rather these go to a forum member and hopefully we can put together a good how to guide for others  :smiley:
The bits I have are: -
2 x LED Xenon Headlights (UK RHD Spec)
2 x OEM Bulbs D1S Bulbs
2 x Bulb Retaining rings
2 x Hella D1S Ballasts
1 x Kufatec 12-14pin Halogen to Xenon Adapters
1 x AFS (357 C controller)
1 x BCM Controller (latest 87E Z0K version running 575 software)
So to complete for the same install as mike you will need the 2 x AFS Power Modules, Kufatec AFS Loom and the Self level sensor (about £200-£300 max depending on where you pruchase the bits from).
If anyone is interested please let me know  :cool:
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #4 on: 25 March 2011, 14:34 »
You can wire the main beams to work without changing the BCM as I have, not easy to explain though.
I can help you with your no fogs / main beam warnings too  :wink:
Offline OKENEMEM
« Reply #5 on: 25 March 2011, 16:07 »
yea the one from ebay about a month ago , they also had a gti rep also
Offline OKENEMEM
« Reply #6 on: 25 March 2011, 16:10 »
im am totally new to this , what on earth is a bcm
is there a step by step guide or should i jus take it to the dealers ,
what kinda money would they charge me to fix the shutter problems
Offline The Doc
« Reply #7 on: 25 March 2011, 19:07 »
Bcm= body control unit
No step by step guide
About £2500 if they could fix it at a guess
Have a great weekend  :wink:
Offline DRC
« Reply #8 on: 25 March 2011, 19:21 »
Yeah silly money! Theyve been fitted to a car that didn't originally come with them. Take it to the Doc, he'll sort you out ;)
« Reply #9 on: 25 March 2011, 19:24 »
Take it back to where you got it and tell them it's not roadworthy. Then report them.
Or see Herr Doktor...... :smug:
