Author Topic: My mk3 1.4 banger  (Read 50916 times)
Offline Ferdinor
Re: My mk3 1.4 banger
« Reply #60 on: 28 April 2011, 15:26 »
Its been a while since i have done an update on this so i thought i had better do one  :smiley:
So i have finally got around to spraying all the rust patches, they turned out ok, i think i have worked out a way to tidy them all up but i cleaned the car today to see how it looks  :wink:
Some reflection shots
The bumpers looked terrible before so i did a before and after using auto bumper care
Bumper care on the right before on the left  :smiley:
Pretty much finished of one of the 4 arches
Before
After
Pretty happy with the result not bad for a couple of hours cleaning  :smiley:
Offline stow1985
  • 'when im cleaning winders'
« Reply #61 on: 28 April 2011, 17:27 »
You've done well there mate!
now to get the boot painted  :wink:
Offline Ferdinor
« Reply #62 on: 28 April 2011, 21:51 »
Thanks, might not spray the boot as i can get one from a scrap yard fot £10  :laugh: Just need to find one the right colour  :undecided:
Offline rcsammy
« Reply #63 on: 28 April 2011, 22:52 »
looking good, that rust on the rear arch, have you polished or t cutted that? matches really well
could easilly get a boot in your colour from the scrapyard near Nick
Offline GrandMstRamRod
« Reply #64 on: 28 April 2011, 23:24 »
good work on rust dude!
Offline Ferdinor
« Reply #65 on: 29 April 2011, 13:50 »
Cheers mate  :smiley:
Sam i just washed the whole car then used some triplewax i got from work consentracted on that one arch for 20 mins and it came out like that  :grin: Started doing the front arch so it works well  :wink:
Offline Ferdinor
« Reply #66 on: 30 April 2011, 22:19 »
Little update
Just ordered some parts ready for its service, got some oil, oil filter, disturboter cap/arm and a sump plug, just need to order plugs and leads and get myself a pipercross air filter and im all done  :smiley:
Offline rcsammy
« Reply #67 on: 01 May 2011, 21:52 »
hopefully that sorts your engine problems out, have a check the plugs are on the right cylinders when you put them on
Offline Ferdinor
« Reply #68 on: 03 May 2011, 21:29 »
Yeah well when they turn up i will fit them  :smiley:
Had a forum member tell me how to set the timing up and where to place the cap so should be all good  :wink:
Ordered some sparks aswell now, so just need money for leads, as my filter is pretty decent  :smiley:
Offline Ferdinor
« Reply #69 on: 13 May 2011, 23:03 »
Well dont get much of a chance to update this but i have done a fair bit to the car now, dont have many pictures but i will post the ones i can find  :smiley:
Right so i have now done a full service on the car, minus ht leads...... need to get some money together for them, so i have finally got rid of all the gunk in the oil and solved the miss fire, but now i have come across a new problem, witch is,....... the revs seem to stick at like 2k and 3k and wont go back down all the time, now im not sure if its due to the auto choke maybe? but when i unplug this plug (not sure what it is) It then begins to idle perfectly fine?
So if anyone knows what sensor this goes to and what it does that would be great  :smiley:
ok so whilst i was trying to solve the problem i thought i would clean the tb whilst doing that i found this.....
Would this make an air leak or is it pretty tight seal still? if so are these expensive?  :undecided:
Also finished the front end looking good i think  :cool:
If you know the others to any of my questions would be great to here them thanks :) Going to make a post in mk3 section aswell  :smiley:
