Author Topic: My mk3 1.4 banger  (Read 50903 times)
Offline trog_nfs
Re: My mk3 1.4 banger
« Reply #100 on: 07 June 2011, 09:25 »
If you're putting your battery in the boot and enclosing it like that, I would connect the vent on the battery to the outside.
Should be small hole on the side of the battery. You can fit a little elbow into it (Some batteries come with them) and a bit of tube to the outside.
I think its hydrogen gas they produce normally, but they can produce some horrible fumes if something isn't right.
« Reply #101 on: 07 June 2011, 10:46 »
Battery in the boot needs to be a sealed type with a vent pipe to the outside world, standard battery will be no good and if anything could be dangerous.  :smiley:
Offline trog_nfs
« Reply #102 on: 07 June 2011, 11:09 »
Isn't it normally the battery that causes cars to burst into flames when involved in an accident?
Offline Ferdinor
« Reply #103 on: 07 June 2011, 12:50 »
Thanks for the thoughts guys, but my dad works as a caravan engineer and has told me everything i need to do to make it safe, if it can sit in a caravan then it can sit in my boot  :grin:
Everything will slowly come to light  :smiley:
« Reply #104 on: 07 June 2011, 13:18 »
So is it a sealed battery, if not then it will vent hydrogen which in a enclosed space is not good. :smiley:
Offline Ferdinor
« Reply #105 on: 07 June 2011, 13:22 »
Nop it is a vented battery with a breather pipe, whitch shall lead to the outside of the car, and the mdf box shall be made sealed at the bottom incase of a leak  :smiley:
Offline trog_nfs
« Reply #106 on: 07 June 2011, 13:25 »
Aha, it was hydrogen! Thanks Wayne, that was going to bug me all day.
Thought so.
Offline Ferdinor
« Reply #107 on: 07 June 2011, 13:28 »
So a vented battery with a breather pipe isnt so bad im guessing? its either this or find space in the engine bay, its a 1.4 so there should be room? what do you reckon?  :smiley:
Offline trog_nfs
« Reply #108 on: 07 June 2011, 13:29 »
Thats the set up exec cars like BMWs and Mercs have. Used to change the batteries for Halfords
Offline Ferdinor
« Reply #109 on: 16 November 2011, 15:47 »
Hi guys i know its been so long since i have been on the forum and posted about my car so i thought it was about time to show you the progress so here goes i dont have many photos just a few from before i last posted to half way through and how it looks now so here goes  :cool:
so last time i was on here i think my car looked something like this
Well after this photo i have been doing a lot of home spraying and managed to get the car to look something like this
As you can see it now has part coloured coded bumpers with a gloss black strip all the way round the car and if any of you remmeber it used to have a black boot well you will happy to know now it has a red one  :grin:
So the last two things that have changed since that photo are............ Coilovers
And i sprayed my steelies
This is how the car sits now and will do until i can afford rims  :cool:
I hope you like  :smiley:
« Last Edit: 16 November 2011, 15:49 by Ferdinor »
