Golf mk2
Heat shield rattle....
Topic: Heat shield rattle.... (Read 1641 times)
James Q
GTI forum regular
22 March 2011, 19:47 »
Hey guys my heat sheild rattles when i pull off or accelerate, is it safe to take it off or can it be screwed back in place or is a new one needed??
clipperjay
Re: Heat shield rattle....
22 March 2011, 20:20 »
Depends if its on the bulk head or under the car, not sure what car you have, but most are held on by circular metal clip buttons usually they rot and fall off or the stalk holder is rusted to bits! The last time VAG charged me for those clips it was like £2.00 a clip and I ordered about four of them. Did the lot at the time. Bulk head ones have a plastic ones that hold the brake pipes at the bottom I would not recomend taking that one off as manifold pipes (16V) can cook your wiring loom!
http://www.golfgtiforum.co.uk/index.php?topic=170521.0
http://www.golfgtiforum.co.uk/index.php?topic=55336.msg427955#msg427955
James Q
GTI forum regular
22 March 2011, 20:22 »
sorry forgot to mention its the 8v gti, it sounds like its from the rear of the car.
clipperjay
22 March 2011, 20:33 »
Ok just check if you can see a stalk or stub left? If you do then you need item 17 on this website I'm sure I have the correct part number somewhere?
http://webcache.googleusercontent.com/search?q=cache:0BMuqyZiYaYJ:www.wagenstad.com/index.php%3Fmodid%3D178%26page%3D2-65-00+circular+heat+shield+clips+golf&cd=20&hl=en&ct=clnk&gl=uk&source=www.google.co.uk
17 + N 903 350 04 clamping washer 5X30
Check the condition of the rubber exaust hangers as they could be finished and its that banging on the tunnel?
Wayne
Sir Postalot
22 March 2011, 20:36 »
Better to refit it tbh.
James Q
GTI forum regular
22 March 2011, 20:46 »
I will order new exhaust rubber and also get the heat shield fitted :-)
gavL
Here all the time
Reply #6 on:
23 March 2011, 15:47 »
Anyone know if they do new exhaust underbody heat shields. When taking mine off to do the gear linkage it just literally disintegrated
| DubNorthEast |
Golf mk2
