Author Topic: V5 2001 170 New member advice??  (Read 1315 times)
Offline ST270
« on: 22 March 2011, 15:52 »
Hi all, I am a new owner of a V5 and I wanted to ask folks opinions on an issue - the engine management light is on and after reading near endless posts about the various sensors needing replacing I am a little lost.
I have had the car on a diagnostic reader at my friends garage and the code 17748 came up which is incorrect correlation of 2nd cam I believe.  The garage has confirmed that the sensors look to have been changed recently and the throttle body is new.  The car has done 98k and I understand that the chains, tensioners, guides etc need checking around this time? - also that the oil pressure needs checking to ensure the correct pressure is there for the tensioner??
Symptoms;
The car accelerates very smoothly with no flat spots, misfires or hesitation - also there is no metallic knocking / roughness or evidence that the chain is slapping etc - the only noticable thing is a slightly lumpy idle which goes away when the climate control is switched off.
I understand that the V5 does have a slightly heavier idle that the 4cyl models on most occassions and my post might seem as if I am grasping at straws however the fault code concerns me as it could potentially be a chain replacement which is an engine out job as I understand it.
Can anyone shed any experience or thoughts on the matter - the garage has advised to run the car a while and monitor for changes etc - perhaps this is a good idea as I have only had the car for a few days?
Any help is appreciated.
Re: V5 2001 170 New member advice??
« Reply #1 on: 22 March 2011, 20:35 »
Could be a dodgy cam sensor.  :smiley:
Offline tshirt2k
  • Been there...Done that...
« Reply #2 on: 23 March 2011, 21:32 »
Yea as above. But probably best to get vag com on it to give you a better explanation of the fault.
The v5 idle is a problem but I managed to improve it by increasing idle speed in vag com.
Mk3 ABF 16VT Megasquirt V3
