Author Topic: Gearboxes?  (Read 2374 times)
Offline simon20vt
Gearboxes?
« on: 21 March 2011, 13:18 »
On an already long list of 'things to do' on my MK4, i was wondering about swapping to a 6 speed box. I was driving yesterday and i decided to see what top speed i could get out of my 1.8T. I hit 140 (on my private racetrack) :wink: but obviously being restricted by the gear ratios i couldn't go much quicker, and didnt fancy pushing it to the redline and blowing my engine.
How compatible is a 6 speed box, and what else would need changing?
Also, i presume this is going to be better top speed, but i was wondering how acceleration and 0-60 would be affected? How do the gearing ratios compare?
Has anyone swapped from 5 speed to 6 speed box, and if so, what were your thoughts on it?
If you have a 5 speed or 6 speed, or have had the luxury of driving both in a MK4, which would you prefer, and which is better?
Thanks chaps :smiley:
Re: Gearboxes?
« Reply #1 on: 21 March 2011, 13:30 »
From what I have read it is not worth changing due to the work involved plus little gains. :smiley:
Offline +49
Re: Gearboxes?
« Reply #2 on: 21 March 2011, 14:25 »
140mph? wow presuming you got a 1.8t 150bhp?
Driving mine it seemed to struggle past 120MPH obviously it would go faster but the you need a long straigth road.All on a private race track of course!
Yeah I wouldn't mind  a 6 speed box the 5 speed is sooo lowly geard 70mph is just over 3krpm is I remember correctly very low geared car tbh it can comfortable drive around town at 35-40mph in 5th  gear!
but as above heard it's not a worth while conversion!
Offline Imteyaz
Re: Gearboxes?
« Reply #3 on: 21 March 2011, 20:22 »
I was looking at getting the 5th gear swapped out for a slightly taller gear ratio, better for cruising at motorway speeds / higher top speed...
Ive heard that it's possible to do without taking the box off but not sure what sort of cost would be involved or where to get a suitable 5th gear from.
See here for a guide / DIY:
http://www.brickwerks.co.uk/images/stories/5thGearMod/21336gearswap.pdf
Offline golf-sib
  • Турботазик
Re: Gearboxes?
« Reply #4 on: 21 March 2011, 20:33 »
Don't see a point as on the s3's the 6th gear has the same ratio as the 5th gear on a 5speed. Which baffles me of the point of having a 225bhp-260bhp car that has closer ratios and a sh!t final gear. Not sure what the golf gear ratio's are on the 6speed...
Ideally a 6speed gearbox needs to have all 1-5 gears of a 5speed gearbox and a higher 6th gear ratio, which I believe some lads use a gear off a tdi to do the trick.
A lot of work for little gain IMO.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline mikemk4gti
Re: Gearboxes?
« Reply #5 on: 21 March 2011, 21:21 »
I used to have a 2002 90bhp tdi, i managed 120-125mph on the autobahn in germany!
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline tech1889
  • Mk2 GTI FTW !!
Re: Gearboxes?
« Reply #6 on: 21 March 2011, 22:35 »
125 on a autobahn  :grin: :grin: :grin: :grin:
Re: Gearboxes?
« Reply #7 on: 21 March 2011, 23:28 »
Spot on :afro:
Offline navmk4gti
Re: Gearboxes?
« Reply #8 on: 21 March 2011, 23:49 »
i have a stage 1 agu and most i have hit is 130ish was struggling after that quite a bit and never had enough private runway or whatever crap to see if it will hit the 140 mark  :embarassed:
Offline turbomick
Re: Gearboxes?
« Reply #9 on: 22 March 2011, 00:41 »
i have i agu and it pissers 130 with out any dowts and gets there quite quick  :grin: :grin:
