Author Topic: Gearboxes?  (Read 2379 times)
Offline golf-sib
  • Турботазик
Re: Gearboxes?
« Reply #10 on: 22 March 2011, 08:10 »
AGU to 140mph is fairly easy from my experience.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline turbomick
Re: Gearboxes?
« Reply #11 on: 22 March 2011, 12:46 »
^^^^^ +1 :grin:
Offline simon20vt
Re: Gearboxes?
« Reply #12 on: 22 March 2011, 13:06 »
Mine is ARZ, but KO4'd, but with a really crap map, only putting out 221 at the fly - i bought the car like it  :sad: but it does get there quite quickly - thing that made me ask was that i was racing a Focus ST, on the racetrack of course, and i had him quite comfortably up to about 130, when he started gaining on me, which just made me wonder about a longer 5th gear and top end speed
I know standard out the factory, VW claim 134mph, but i doubt its possible when the car is 10 years old.
Whats top speed on S3 or TT 225? both have 6 speed boxes, so would be quite easy to compare the factory figures
Would 6 speed decrease 0-60? but slightly increase top speed - all be it, not by much?
Whilst we are on the subject of gear ratios and boxes etc, im gonna throw the 4wd debate in, if i was running around 270 with KO4 - would it be worth doing 4wd conversion to put the power down a bit better than all through the front wheels, or not worth the hassel?
Offline +49
Re: Gearboxes?
« Reply #13 on: 22 March 2011, 13:44 »
humm well i dunno what you guys consider quick to 130mph but the AGU is standard form is far from being  quick to this speed.
Maybe because my RSV hit's 150-165mph a number of times (without trying) on most rides I dunno.On same roads the GTI will stuggle to hit 3 figures
All on the track of course :D
But yeah its geard really really low which doesn't help with the fact the engine is resistent to rev compared to N/A..by 5000-5500rpm its about out of ideas..So pulling to redline in top is ni on impossible.Shifting at 3500-4000rpm is a really nice engine IMO of course  :wink:
Offline simon20vt
Re: Gearboxes?
« Reply #14 on: 22 March 2011, 17:15 »
+1  i think we are all talking about our own individual cars, remapped to 200bhp ish plus, rather than standard, think we all know they are rather slow at a standard 150bhp  :smiley:
Offline golf-sib
  • Турботазик
Re: Gearboxes?
« Reply #15 on: 22 March 2011, 17:55 »
At 150bhp they are really disappointing cars, should of been at least 180 minimum out the factory, don't get me started on the brake and suspension setup either!
As for your 4wd question, don't waste your money either get a 4mo car and drop a 1.8T in or just buy a s3/tt/a4 etc in quattro with a 1.8T. The costs and work involved are not worthwhile IMO. Plus putting power down is not an issue, I have been in a LCR mk2 with 360bhp and the diff is amazing, no torque steer at all when all that power is put down (so 4wd is not a must, yes it helps during luanch and handling, but if we are talking about the 8L s3 etc of them years then the haldex system was not that great, bit slow to kick in when needed and not as responsive).
Extending 5th gear has its ups and downs, you would need to up the power otherwise acceleration would be pants on a longer 5th gear, unless off course your modding it to do 70mph on non stop motor way journeys.
As for the 6speed on a S3, the 6th gear ratio is the same as the 5th gear on a 5speed gearbox, so top end should be same maxed out!
As for closer gear ratio's again, has its ups and downs. Acceleration wise the gear shifts whilst driving/racing will be changed much more frequently which is major speed/time loss during transmission. However acceleration would be quicker, but you have to weigh that against the time lost on shifting. Then you have another issue having short gears means that the gears act as bigger multipliers and traction would be kicking in more frequently to control that power on the ground on lower gears, but in higher gears it may benefit...
Personally I would stick with a 5speed box
1.8T AGU..
R135
  24
Offline simon20vt
Re: Gearboxes?
« Reply #16 on: 22 March 2011, 20:24 »
and thats todays tutoring about the pros and cons for 5 and 6 speed boxes and 4wd  :laugh:
learnt all about it just reading that haha
Thanks buddy, big help  :smiley:
