Golf mk2
Door catch question
Topic: Door catch question (Read 1169 times)
cheesypeanut
Door catch question
14 March 2005, 18:52 »
Quick question; will the catch from a 3 door fit a front door on a 5 door?
Cheers.
Gambit
Forum addict
Re: Door catch question
14 March 2005, 18:59 »
yes
cheesypeanut
14 March 2005, 19:40 »
Sweet, thanks.
Final thing, can someone hit with a rough how-to on fitting them? Is it as simple as unbolt -> remove -> replace -> bolt on or is the process a little more challenging?
...joe
Forum Supporter
Forum addict
14 March 2005, 20:36 »
pretty much as you say!
undo the two allen key bolts
pull off
get knew one
line up relevant sliding parts (you'll see what i mean)
push into place
do up bolts
the most awkward part is hooking the wire from the inner door onto the sprung clip on the catch. its not too fiddly but you can slide a small screwdriver up through a hole from below the catch to keep it from moving too far. as you pull away the old catch if you do it slowly you'll see the wire on the sprung part at the bottom of the catch so you'll know what i'm on about.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Golf mk2
Door catch question
