Author Topic: Tappety tappety tap  (Read 5686 times)
Offline Dream Police
Tappety tappety tap
« on: 04 September 2003, 20:46 »
My MkII 8v has developed an annoying sticking tappet, Ive had various advice such as
flush with oil/paraffin mix,
buy some engine flushing agent and try that
buy a new engine!
Im nearly resigned to the fact that I will have to replace the tappet but I just thought Id ask if any of you had similar problems and had tried flushing it out.
Ta
I voted for Pedro
Offline richandhazel
Re:Tappety tappety tap
« Reply #1 on: 04 September 2003, 23:52 »
I've not done it, Hazels Audi hasn't got that bad..........yet!!
But I have heard, flushing it through does work. Might be worth a try.
golfvr6
« Reply #2 on: 05 September 2003, 00:00 »
Wynns flushing oil is good, you can get it at Halfords. Run the engine at idle only until the cooling fan has cut in a few times then drain it all and fill up with fresh oil. Got to be worth a try.
Offline modulater
« Reply #3 on: 05 September 2003, 00:23 »
Be worth trying the flusher first, also maybe change the grade oil and see if that helps.
Might be worn out, whats the mileage?
golfvr6
« Reply #4 on: 05 September 2003, 14:04 »
Changing tappets on an 8v is not a big job  :)
« Reply #5 on: 05 September 2003, 17:47 »
About 106K
I voted for Pedro
golfvr6
« Reply #6 on: 07 September 2003, 10:27 »
The tappets do become very worn at over 90-100k if the car isn't properly serviced in its life. Try the oil flush otherwise get a new set of tappets.
Offline edjay
« Reply #7 on: 11 September 2003, 14:21 »
Hi
Had the same problem on my 8V. Starting using Shell Optimax & the tapping stopped. If for any reason I can't get Optimax & have to fill up on the normal stuff the tapping comes back.
Offline GTI16vGaz
  • New car will be displayed soon.
« Reply #8 on: 11 September 2003, 14:30 »
My tappets are the same, GOLFVR6 how much are a new set of tappets have you any idea? and thanks for all the advice, my car's done 137,000 and like you said they start to wear between 90-100, 000 if the car has not been serviced properley, which i don't now because i bought it at 135,000 so they probably need doing.
Thanks again!
Garry
« Reply #9 on: 11 September 2003, 14:42 »
Hi
How odd? Although I readily recommend using Optimax I can't see how it would effect tappet noise.
Pinking which is more of a rattling noise under load, would benefit from Optimax.
Are you sure it is tappet noise that you have?
