Author Topic: FFS!! I shouldnt be aloud near cars!  (Read 4080 times)
Offline the_stink
  • A3 140 TDI
« on: 13 March 2011, 10:55 »
So had a few more things to change mainly the dizzy and rotar arm and ignition leads
So replaced them all and then when i went to start the car nothing then a bit of a pop so im assuming that's a misfire and a spark pluh has gone? would this be down to putting the ignition leads on in the wrong order?
Offline X4MGS
  • VAG Parts SNOB!!!
Re: FFS!! I shouldnt be aloud near cars!
« Reply #1 on: 13 March 2011, 10:57 »
Sounds like it... Could also be that you have put the Dist cap on wrong...
Get the haynes manual out!!
For More Info Click To See;
Offline the_stink
  • A3 140 TDI
« Reply #2 on: 13 March 2011, 11:01 »
ok ill have a look at the haynes, when i looked at the new and old dizzy cat they looked exactly the same
failing that is there anyway to remedy this? :(
Offline the_stink
  • A3 140 TDI
« Reply #3 on: 13 March 2011, 11:13 »
just had a read through the haynes and the only thing i can think of is that the HT leads are connected in the wrong bloody firing order
so after a quick search if read that the order is 1342
now on the dizzy which one way does it go? and which lead is 1 is it the one closest the oil cap  :embarassed:
« Last Edit: 13 March 2011, 11:16 by the_stink »
Offline Horney
« Reply #4 on: 13 March 2011, 11:25 »
Easy mistake to make fella. I always number my leads (Blobs of tippex,1 on ead 1, 2 blobs on lead 2 etc) and then change one lead at a time and then change the dizzy cap.
Anyhoo Haynes should tell you how to do it but it's quite simple.
Take out spark plug 1 (Nearest the airbox) And stick a chopstick down the hole. Rock the car back forth in 1st gear by pulling on the slam panel until the chopstick reaches the highest point. You've now roughly found Top Dead Centre for Number 1 cyclinder. Pop the dizzy cap off and you should see the rotor arm will be roughly pointing at one of the leads. That lead should be connected to plug number one. You then have a starting point to work out the rest of the leads :o)
Nick
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #5 on: 13 March 2011, 11:35 »
Read the timing part of RJ's how to tune Digi..
http://www.golfgtiforum.co.uk/index.php?topic=33253.0
Offline the_stink
  • A3 140 TDI
« Reply #6 on: 13 March 2011, 11:42 »
cheers guys well ive managed to sort the HT lead order our and got the car started
But
it doesn't sound to healthy a bit lump and tbh i don't really want to drive it ive taken a video ill try and post up in a bit see what you guys think, and i right in thinking that that first attempted when i heard the loud pop/bang was a spark plug saying bye bye
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #7 on: 13 March 2011, 11:51 »
prob just a back fire... but take them out and check them...
Offline the_stink
  • A3 140 TDI
« Reply #8 on: 13 March 2011, 11:54 »
i havent got a spark plug tool :(  or is it just a specific wrnech and extention?
dont know if it was just me but there was a strong smell of fuel at the back of the car, would this be due to it misfiring?
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #9 on: 13 March 2011, 11:56 »
thats cos the pistons are full of fuel thats not e getting ignited in the correct order...
There's no point putting new leads on and not fitting new plugs... get a tool and new plugs fitted..
