Author Topic: Change Fuel Filter  (Read 4143 times)
Offline mani12354
Change Fuel Filter
« on: 10 March 2011, 11:27 »
Hi,
does anyone no how and where to change the fuel filter on MK3 Golf GTI 2.016v
 :rolleyes:
Offline Gash
Re: Change Fuel Filter
« Reply #1 on: 10 March 2011, 12:04 »
I can't remember how to change it but jack the.rear.up and its on the dricers side next to the fuel tank. Should see it easy enough
Offline N900 MJT
« Reply #2 on: 10 March 2011, 12:07 »
+1 - doesnt it just pull away from the pipes?
Offline Khare
  • The bear that khares
« Reply #3 on: 10 March 2011, 13:09 »
It has I think it's two straps around it, they're on with a nut each iirc.
Then one line on each side, fit new jubilee clips around them  :smiley:
Oh and make sure you fit the filter in the right direction.
Offline mani12354
« Reply #4 on: 10 March 2011, 13:11 »
thanks everyone for that..
but isit in the engine bay or isit at the back
and isit hard to do?
 :huh:
Offline VR6_Wherry
« Reply #5 on: 10 March 2011, 13:12 »
It's under the car and it's easy, even Shady could do it..
Offline Khare
« Reply #6 on: 10 March 2011, 13:14 »
Yeah it's under the car. In front of the rear offside wheel, underneath where the passenger behind the driver would sit.
Offline mani12354
« Reply #7 on: 10 March 2011, 13:16 »
how long should it take me?  :shocked:
« Reply #8 on: 10 March 2011, 13:18 »
Don't forget to pull the fuse for the fuel pump and run the car untill it stops, this will release the pressure in the fuel system.  :smiley:
Offline Khare
« Reply #9 on: 10 March 2011, 13:19 »
Yup forgot to mention that too!
30 minutes max from start to finish for a beginner. It's an easy job.
