Author Topic: Problems with the valver  (Read 5679 times)
Offline Sam
  • Sam I am
« on: 09 March 2011, 22:46 »
Right, ran a compression test today and cylinders one and 4 are very low (plugs had oil on them too). She is chucking oil out the zaust, back of block and exhaust fumes out of my oil catch tank. Am I right in thinking its either rings or head gasket?
Much love, Caistor 'about to have to strip his entire engine and hit it with a hammer' bmx
Offline danny_p
Re: Problems with the valver
« Reply #1 on: 09 March 2011, 22:57 »
yup its broken.
and its head off block o clock
all the VW's have gone bar 1.
Offline Sam
  • Sam I am
« Reply #2 on: 09 March 2011, 23:06 »
yup its broken.
WHOOP WHOOP! Where can I get the splein tool from to unbolt the head? And also am I right in thinking that the cams will lift out with the head?
« Reply #3 on: 10 March 2011, 00:00 »
Yes they do, sealey do the spline tool you need
Offline Sam
  • Sam I am
« Reply #4 on: 10 March 2011, 13:22 »
Cheers wayne, done spose hellfrauds or machine mart do such a tool do they?
« Reply #5 on: 10 March 2011, 13:22 »
They should do :afro:
Don't forget to fit new bolts btw.
Offline Sam
  • Sam I am
« Reply #6 on: 10 March 2011, 14:06 »
No worries; so it new head bolts, pretty much full gasket set for cam gaskets too and new cam belt obv. Anything else? I have never done a head gasket before so need all the help I can get before I start
Offline DOA
« Reply #7 on: 10 March 2011, 15:22 »
Get a tensioner with the belt too. Worth working out whats actually wrong with the engine first before buying all the kit though.
Offline Sam
  • Sam I am
« Reply #8 on: 10 March 2011, 15:31 »
Low compression leads to me having to take the head off anyway so all this stuff is getting replaced no matter what. Hardly going to use the same head gasket again  :grin:
Offline andyholli
« Reply #9 on: 11 March 2011, 08:09 »
I'd be thinking about valves out for a clean up, reseat and new stem seals while the head's off. -Maybe get the Dremel for some more excitement.
If you'd like another KR lump to prepare while you continue to drive (smokily) around I've got one sat in the corner that you can have for £50..
Good luck :smiley:
Andy
