Author Topic: 1993 MK3 Golf(VRT Engine build time!!)*UPDATED 17/3/13*  (Read 259876 times)
Offline Seanl
Re: 1993 MK3 Golf(Engine build time!!)
« Reply #630 on: 31 August 2012, 18:51 »
I was expecting more than this. :lipsrsealed:
Nah, looks great bud! Couldn't u have just used some nitromors though?
Offline LowlifeDubber
« Reply #631 on: 31 August 2012, 18:55 »
Theres no bloody pleasing you! :grin:
I could have used nitromors but it wouldnt have remmoved all the loose deposits etc so i would have had to go over it all with the brushes anyway.
Although to help me out on the other side i have tipped a load of thinners over it then it will have time to soak in over the weekend ready for tuesdays scratch fest lol
Offline leigh_harty
  • Audi AGU
« Reply #632 on: 02 September 2012, 18:54 »
Been for a spin in a vr turbo again today... 'only' running 13psi  :evil:
Yours should be quite awesome when built  :cool:
Dont lose your dinosaur!
« Reply #633 on: 11 September 2012, 17:28 »
Right so ive been doing a few bits here and there with Potter over the last week inbetween fixing other peoples cars.
Engine wise.The block is completely stripped and ready for rebuild and then paint.I have everything for the bottom end bar the conrod bushes and crank thrust washers.GSF should have had these in for me last tuesday however a phonecall today revealed they are still in Belgium but will be here friday. :rolleyes:
Anyway rather than fit the R32 alloy sump and shorter oil pump i decided to plate the standard VR6 pressed metal affair.
I basically made a cardboard template then copied this over onto a 3mm MANGANESE plate bashed it about aand formed it round the sump and then welded it up.To protect the sump plug which is the lowest area I cut a 1/2bsp shed 10 pipe down the centre and welded this to the plate.
Should do the job.
Just got to fettle it up and then black enamel the bad boy and its ready to go on.
I also got this from Matt in the states who came over to Edition38 show with a few parts and Bucksfizzturbo was kind enough to pick it up from the show and post it over to me when he got home.(Thanks again Nath)
As it happens it was just the glass and no back plate so i had to remove the origina backing plate off a spare i had and then use some pink grip to restick it to the back.
Heres how it looks and im well chuffed.
Also got my front crossmember ground down and fettled ready for paint.Also whipped the cv joints off the driveshafts and cleaned this down.Made a start on the gearbox too but no pics of that as it isnt finished.
They are all in the garage with the 1st coat of paint on them.
Today ive spent a good few hours stripping the rings off the forged pistons and set about polishing the crowns for reduced carbon build up and just plain prettyness. :evil:
Oh i stripped all the valves out of the cylinder head im using the other day and sent it to be skimmed.They have taken 0.20 thou off it.
Then instead of taking it somewhere to get a mediocre port and polish i decided to do it myself.
So i have bought this.
Should do the job nicely ;)
Ive also received the rest of the bottom end gasket kit and all the coreplugs so its just a case of waiting for the bits from GSF and i can build the bottom end up and paint it :)
Im also waiting for a NewSouth performance inlet manifold gasket.Should help to keep inlet temps down.Bloody expensive though!
http://www.newsouthperformance.com/gasket.htm
Oh and i had my 13 Row Mocal oil cooler arrive last week too!
In other news i took Potter on it's 1st longish trip(100mile) to a car meet in Hull for sh!ts and giggles.
Crappy pic off my phone but you get the idea.
Thats it for now :)
Offline brett
« Reply #634 on: 11 September 2012, 17:40 »
top work as always mate ,wish i could get that motivated lol
Offline DCmk3
« Reply #635 on: 11 September 2012, 17:59 »
Looks good, just one thing stands out to me, will that raised section on the sump above/under the sump plug not hook on the floor if you're reversing?   :lipsrsealed:
2014 Mk7 GTI - Littco L500
« Reply #636 on: 11 September 2012, 18:03 »
Thanks again mate.  :smiley:
I did wonder that myself but when i checked the angle the sump plug protector would sit at when fitted the highest point ill be about 25mm into the centre of the piece so it wont be a problem.
Good eye though. :wink:
Offline DanChave
« Reply #637 on: 13 September 2012, 18:03 »
Great engine work mate! I would love to get this involved!
« Reply #638 on: 13 September 2012, 18:19 »
Thanks mate. :cool:
Ive had a busy day today doing various engine related jobs but cant be arsed to upload pictures just yet.
Im thinking tomorrow. :grin:
« Reply #639 on: 13 September 2012, 23:54 »
That seems a lot to have skimmed from the head   :undecided:
