Author Topic: HELP! Pioneer DEH - 5200SD  (Read 2953 times)
Offline mani12354
« on: 08 March 2011, 19:09 »
I got a pioneer deh 5200sd  and it was working this morning and all of a sudden it stoped working :S the car was off most of the day and my amp wouldnt turn on i checked all fuses and wiring their was no fault :| help sombody :cry:
Offline trog_nfs
Re: HELP! Pioneer DEH - 5200SD
« Reply #1 on: 09 March 2011, 20:26 »
so the radio fuse is fine and so is the wiring?
Pull  the radio out, and check you have pernament voltage (excuse the spelling), and check you have ignition voltage (Red and yellow wires in the loom) If both of those are fine, the radio must be knackered, so take it back.
Offline mani12354
« Reply #2 on: 09 March 2011, 20:50 »
i tested the radio it worked fine it was working the other day fine and all of a sudden stoped  :shocked:
Offline trog_nfs
« Reply #3 on: 09 March 2011, 21:11 »
well is there ignition voltage and pernament voltage to the radio?
Offline mani12354
« Reply #4 on: 09 March 2011, 21:15 »
what do you mean?  :huh:
Offline trog_nfs
« Reply #5 on: 09 March 2011, 21:53 »
well the power source for the radio comes from two sources in the car. The first is the permanent live, usually a yellow wire, which is the fused power source that comes straight from the battery via the fusebox. This is what gives the radio power and its memory to store radio stations.
The second is the ignition live, usually a red wire, which is a feed from the ignition switch that tells the radio to switch on when the keys are in the ignition.
The radio needs both of these to function. If the fuse hasn't blown, you should find the pernament live gives 12v no matter what. The ignition live should only be 12v when the ignition is on. If its in an old VW, the ignition switch can fail, and will stop your radio switching on.
Have a look at the wiring with a multimeter if you are definately sure you haven't blown a fuse
