Author Topic: Jacking points advice please  (Read 11289 times)
Offline tech1889
  • Mk2 GTI FTW !!
Re: Jacking points advice please
« Reply #10 on: 11 March 2011, 19:00 »
corr mine dont look like that lol
Offline emery1990
« Reply #11 on: 11 March 2011, 19:02 »
Jack went through the other day lol Thought why Cant I put my wheel on, jacked it up more then it cracked!
Offline Reasty
  • Alpine white valver.
« Reply #12 on: 11 March 2011, 21:41 »
you say you had them all welded up i need one maybe 2 of my front ones done how much did you get charged to have this fixed ??
It cost me the best part of £400 labour BUT! as i said i didnot just have them repaired i had the whole section cut out so there was no rust then i had the same section cut out of another mk2 with perfect jacking points then had that welded in and the seals rebuilt,its such a good job that they are now stonger than ever and also it looks oe which is what i wanted,not the cheapest or easiest way of sorting it out but i am abit anal when it come to my mk2   :grin:
Offline Reasty
« Reply #13 on: 11 March 2011, 21:54 »
It ended up looking like this before it was undersealed and now its all dirty it looks spot on.
Offline rossbarry1
« Reply #14 on: 17 March 2011, 18:25 »
who did you get to do that? i made the same mistake of loosing a jack point :(
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #15 on: 17 March 2011, 22:24 »
is that a repair panel or ??
Offline rossbarry1
« Reply #16 on: 17 March 2011, 22:28 »
the panel and work?
Offline emery1990
« Reply #17 on: 18 March 2011, 16:07 »
In the pic thats a bit chopped off another mk2 he said. Dads mate came round and dint seem to fussed bout it, so doubt itll cost that much to fix  :smiley:
Offline Ben Lessani
« Reply #18 on: 19 March 2011, 10:56 »
I've always used my proper jacking points - but that said, mine aint a rotbox :D
Rear beam, mid-chassis legs, front chassis legs, front subframe > body section are my supports of choice.
I put them wherever they're not in the way. Chassis legs are structural points - so anywhere on it is fine.
For the front, normally I go for the very front chassis leg where it meets the front x-member - jacking from the rear subframe/front x-member.
For the front, then I jack from the jacking points and support under the chassis leg at the middle/front.
For the rear, if I'm not working on the rear beam, then I support from the rear beam and jack from it.
For the rear, if I'm working on the rear beam, I jack from it and support on the rear mount points (not a great photo, don't have any others).
Offline Reasty
« Reply #19 on: 20 March 2011, 09:31 »
the Phirm did the welding work and it's not a repair panel it is a section cut out of another mk2 that was being broken    :smiley:
