Author Topic: Non running digifant :(  (Read 2595 times)
Offline Winner
« on: 06 March 2011, 19:21 »
Help plz people or any1  :sad: i hav a 1.8 8v digifant that doesnt runn  :undecided: it has a constant spark frm HT lead but there is no electrical feed upto injectors to open them tryed new ecu, new ign modular? where does the e;ectrical feed come from to open injectors is it the hall sensor?  :sad:
Re: Non running digifant :(
« Reply #1 on: 06 March 2011, 19:39 »
I am 99% sure the ECU controls them
Offline Benrevs
« Reply #2 on: 06 March 2011, 23:14 »
Sounds daft but have you checked the relays? Could be hall sender also.
« Reply #3 on: 07 March 2011, 10:42 »
the power for the injectoers comes from ecu relay or fuel pump relay, depending on the age of it (where is your hazard switch?)
the earth feed for them is from the ecu.  does the fuel pump prime? if so check with your multimeter from the red wire to the battery when the pump is priming
Offline Winner
« Reply #4 on: 07 March 2011, 13:00 »
hello there again an answer to ur questions is its on a aftermarket fuel pump which is just wired into an on/off switch which means pumps works fine and as for hazard switch its on dashboard. from the checks i did last night i checked to c if there was a feed down to the injector plug by pluggin a 12volt bulb into wiring loom and crankin engine but light dint light up but it wont if its a switchable earth will it  :undecided: am goin home tonight armed with voltmeter an test light so if u can help anymore wud be much appreciated
thanks people for the help
« Reply #5 on: 07 March 2011, 13:23 »
 :shocked: why it is on a switch
« Reply #6 on: 07 March 2011, 14:33 »
and what pump is it?
Offline Winner
« Reply #7 on: 07 March 2011, 14:36 »
its on a switch cause its an aftermarket pump as i cudnt lay mi hands on orginal pump an its syntec fuel pump its been running on that for last 6 month no problems
« Reply #8 on: 07 March 2011, 14:55 »
ok, fuel injectors are controlled by the ecu relay, is it still there? its a 53 relay in slot 1. try swapping it for another one if its there, you should have another 53 relay for the horns.
if that doesnt help look in your scuttle tray, there are a couple 2 pin plugs where the interior loom plugs into the ECU loom, they are prone to corrosion as they are not waterproof.
« Reply #9 on: 07 March 2011, 15:07 »
Might be worth testing the fuel pressure as well.
